[Nek5000-users] endian problems
Thu Dec 3 07:19:58 CST 2009
- Why do you think r374 will not have the same problem?
- At which timestep did it hang?
#Stefan
On Dec 3, 2009, at 2:13 PM, nek5000-users at lists.mcs.anl.gov wrote:
> It turns out that the old version of the code hangs after a random number of time steps, so I need the new version (r374) to work.
> Quoting nek5000-users at lists.mcs.anl.gov:
>> Yes, the files were written out on a AMD Opteron Linux system.
>> J
>>> Ok and do you need to swap the bytes on Intrepid meaning is your   restart data of small endian type?
>>> On Dec 3, 2009, at 11:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> It's a blahh??.f0001 file. (16 files)
>>>> Johan
>>>>> Is the restart data a .fld?? or a .f???? file?
>>>>> #Stefan
>>>>> On Dec 3, 2009, at 11:08 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hi again,
>>>>>> It seems to work when I use a slightly older version of the code. There
>>>>>> was apparently a change in ic.f where the restart data was read in
>>>>>> ('Reading restart data..' --> 'Reading checkpoint data..').
>>>>>> Johan
>>>>>> Johan Ohlsson
>>>>>> Department of Mechanics, KTH
>>>>>> SE-100 44, Stockholm, Sweden
>>>>>> Phone: +46 8 7906876
>>>>>> E-mail: johan at mech.kth.se
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Johan Ohlsson
>> This message was sent using IMP, the Internet Messaging Program.
