[mpich-discuss] 回复: 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
Pavan Balaji balaji at mcs.anl.gov
Mon Jul 25 21:22:38 CDT 2011
On 07/25/2011 09:19 PM, 游手好闲 wrote:
> [root at hksbs-s11 ~]# env | grep LD_LIBRARY_PATH
> LD_LIBRARY_PATH=/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64:/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64
> DYLD_LIBRARY_PATH=/opt/intel/cce/10.1.018/lib:/opt/intel/cce/10.1.018/lib
> [root at hksbs-s11 ~]# ssh hksbs-s13.com env | grep LD_LIBRARY_PATH
Is your LD_LIBRARY_PATH not set in your shell startup script?
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
