[mpich-discuss] 回复: 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
游手好闲 66152764 at qq.com
Mon Jul 25 21:19:49 CDT 2011
--------------------------------------------------------  in hksbs-s11   ------------------------------------------------------------------------------
 [root at hksbs-s11 ~]# clear
[root at hksbs-s11 ~]# env | grep LD_LIBRARY_PATH
LD_LIBRARY_PATH=/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64:/opt/intel/cce/10.1.018/lib:/opt/intel/Compiler/11.1/064/lib/intel64
DYLD_LIBRARY_PATH=/opt/intel/cce/10.1.018/lib:/opt/intel/cce/10.1.018/lib
[root at hksbs-s11 ~]# ssh hksbs-s13.com env | grep LD_LIBRARY_PATH
[root at hksbs-s11 ~]# ssh hksbs-s11.com env | grep LD_LIBRARY_PATH
  --------------------------------------------------------  in hksbs-s13   ------------------------------------------------------------------------------
 [root at hksbs-s13 ~]# ssh hksbs-s13.com env | grep LD_LIBRARY_PATH
[root at hksbs-s13 ~]# env | grep LD_LIBRARY_PATH
  ------------------ 原始邮件 ------------------
  发件人: "Pavan Balaji"<balaji at mcs.anl.gov>;
 发送时间: 2011年7月26日(星期二) 上午9:32
 收件人: "mpich-discuss"<mpich-discuss at mcs.anl.gov>;
 抄送: "游手好闲"<66152764 at qq.com>;
 主题: Re: [mpich-discuss] 转发:回复: hydra_pmi_proxy: error while loading shared libraries:libimf.so: cannot open shared object file: No such file or directory
On 07/25/2011 07:45 PM, 游手好闲 wrote:
> [root at hksbs-s11 ~]# ssh hksbs-s13.com ls
> /opt/intel/Compiler/11.1/064/lib/intel64/libimf.so
> in fact, it is ok for only in one node(hksbs-s13.com or hksbs-s11.com ).
What does the following command return:
% ssh hksbs-s13.com /opt/mpich2-1.4/bin/hydra_pmi_proxy
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110726/da0bb67e/attachment.htm>
