[mpich-discuss] MPICH2 CPUs Vs. Cores
Reuti reuti at staff.uni-marburg.de
Fri Jul 15 17:26:56 CDT 2011
Am 16.07.2011 um 00:18 schrieb Peter Willis:
> On 7/15/2011 2:50 PM, Reuti wrote:
>> Hi,
>> Am 15.07.2011 um 23:34 schrieb Peter Willis:
>>> I have a single system with 4 CPUs. Each CPU has 12 cores.(48 cores total)
>>> MPICH2 is built and installed from source and there are no errors.
>>> The documentation is a bit vague regarding CPUs  vs. Cores.
>>> QUESTIONS:
>>> 1.)
>>> What is the best way for a single node system to utilize
>>> a maximum number of cores?
>> what do you mean by this in detail? Do your applications scale well with increasing number granted cores?
> The code we are running scales well to 128 CPUs.
> We have contact with another user who has a cluster with
> several machines, 4 cores each machine. They run 64 cores
> total.
> Our system is only one machine with 48 cores. It currently
> only utilizes 4 cores of the 48. In fact the system gives
> a segfault if  mpiexec -n  is greater than 4. (?...)
Are all 4 cores allocated on one and the same CPU?
What about a simple mpihello - is this running well with more than 4 cores?
Running across more than one machine might give more memory in total - depends. What has the other cluster per node and your machine in total?
-- Reuti
> I am trying to deduce if there is a compilation problem,
> a run-time parameter problem, or a process management problem.
> Peter
