[mpich-discuss] Fwd: About using mpi on windows
Jayesh Krishna jayesh at mcs.anl.gov
Tue Jul 12 13:20:57 CDT 2011
 Please contact your sysadmin to find out how to run mpiexec in your system. From the latest (couple of emails back) outputs it looks like you have access to mpiexec (once you specify the complete path) but you don't have access to the example programs in the installed directory.
 Your sysadmin should be able to assist you in running your job.
(PS: Please check with your sysadmin that when MPICH2 was installed it was installed for "Everyone" - An option to be selected while installing MPICH2)
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Tuesday, July 12, 2011 8:30:34 AM
Subject: Re: [mpich-discuss] Fwd: About using mpi on windows
I installed MPICH2 with an administrator command prompt. I am not permitted to log in as administrator, but could you please tell me how this is related to the error that 'mpiexec.exe' is not recognized as an internal or external command, operable program or batch file? I will ask the administrator to log in and try the command. Thanks.
Regards
Ruizi
