[mpich-discuss] unable to get host address
Pavan Balaji balaji at mcs.anl.gov
Wed Feb 23 00:29:21 CST 2011
Dear Nicolas,
On 02/23/2011 12:14 AM, Nicolas Rosner wrote:
> I happen to have an out-of-the-box MacBook here on which I was testing
> some non-MPI software and was noticing, coincidentally, some
> hostname-related quirks that didnt seem quite standard, at least as
> per my Linux-biased expectations of POSIXness. This broke a few
> (unrelated) programs until workarounds were added, and I thought might
> be misleading hydra similarly.
> That said, I just tried and failed to reproduce Alex's problem. Got
> latest stable MPICH2 sources, configured (all as per defaults except a
> --prefix and --disable'ing Fortran). Built OK, added bin to PATH at
> the front (to ensure priority over the built-in OpenMPI), and compiled
> a few of the examples manually. Ran them using your syntax; all worked
> fine, no problem whatsoever.
Thanks for the information. Did you try MPICH2 _after_ you fixed the
hostname related quirks on your machine? If yes, what were the problems
and the fixes you made?
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
