[mpich-discuss] Interesting Problem
Pavan Balaji balaji at mcs.anl.gov
Sun Feb 20 14:06:18 CST 2011
Jeff,
On 02/20/2011 06:53 AM, Evans Jeffrey wrote:
> Installed the patch, re-ran the test - similar result. The PBS output
> file this time is a bit different from the earlier one I sent you.
> Both are attached, the lower number is pre-patch, higher is
> post-patch.
This doesn't look right. The version string in your output says 1.3,
rather than 1.3.2p1. Also, my local testing shows the correct PMI
process mapping string, while the process mapping string in your output
shows no difference.
Are you sure you are using the correct version of mpiexec?
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
