[mpich-discuss] Interesting Problem
Evans, Jeffrey John jje at purdue.edu
Sun Feb 20 14:37:44 CST 2011
I'll check again. I'm using 1.3.2 at the moment. Do I really need p1?
jje
On Feb 20, 2011, at 3:06 PM, "Pavan Balaji" <balaji at mcs.anl.gov> wrote:
> Jeff,
> On 02/20/2011 06:53 AM, Evans Jeffrey wrote:
>> Installed the patch, re-ran the test - similar result. The PBS output
>> file this time is a bit different from the earlier one I sent you.
>> Both are attached, the lower number is pre-patch, higher is
>> post-patch.
> This doesn't look right. The version string in your output says 1.3,
> rather than 1.3.2p1. Also, my local testing shows the correct PMI
> process mapping string, while the process mapping string in your output
> shows no difference.
> Are you sure you are using the correct version of mpiexec?
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
