[mpich-discuss] How to config mpiexec use rsh as default bootstrap?
Pavan Balaji balaji at mcs.anl.gov
Sat Feb 19 13:59:29 CST 2011
Thanks Steve.
  -- Pavan
On 02/19/2011 01:54 PM, Steven Sutphen wrote:
> Pavan,
> I sent the the bsci_init.c.in file that I had patched by hand to Limin and it
> worked for him--he has it running now. I hacked up the patch file that
> you had sent to me--replacing the bsc_init.c.in portion with one that I
> generated from the original and patched versions of the file.  The
> "diff" command had different flags (as I was not using git) but I think
> it will work.
> I have attached that file as hydra_UA.patch.gz.
> I also have attached my hand patched bsci_init.c.in file in case the patch
> does not do the trick.
> Thanks,
>       steve.
> On Sat, Feb 19, 2011 at 10:13 AM, Pavan Balaji<balaji at mcs.anl.gov>  wrote:
>> Hi Limin,
>> On 02/18/2011 03:52 PM, Limin Gu wrote:
>>> Is there a way I can get a patch based on v1.3.2?
>> Unfortunately, this patch seems to have a bunch of other dependency patches.
>> The 1.3.x nightly snapshot for Hydra should be quite stable
>> (http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra/).
>> Would you be able to use that in the meanwhile?
>> We are discussing internally if we should pull forward the next release to
>> fix these issues.
>>   -- Pavan
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
