[mpich-discuss] How to config mpiexec use rsh as default bootstrap?
Steven Sutphen ssutphen at ualberta.ca
Fri Feb 18 11:33:38 CST 2011
Limin,
This sounds like a bug that I helped to track down--in my case mpiexec
blew up in
if I set either of the HYDRA_BOOTSTRAP environment variables.  The problem
was that the some of the environment variable handling allocates some
memory that is freed up in some tail code that is common to all the
environment variables the HYDRA_BOOTSTRAP* environment parsing does
not allocate any memory so the pointer used later to free it contains garbage.
Pavan developed a patch that worked for me (after a little hand-to-hand
combat with one chunk of the patch as the patch was not developed with
exactly the same files as were distributed in tarball.  I have attached
the patch, but try it at your own discretion.
    steve.
On Fri, Feb 18, 2011 at 9:47 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Setting the HYDRA_BOOTSTRAP and HYDRA_BOOTSTRAP_EXEC environment variables
> should work. What error are you seeing?
> Alternatively, you can reconfigure MPICH2 as with
> --with-hydra-bss=rsh,ssh,fork,slurm,ll,lsf,sge,pbs,none,persist
> This will reprioritize the launchers to give a higher priority to rsh.
>  -- Pavan
> On 02/18/2011 10:39 AM, Limin Gu wrote:
>> Hi,
>> I have successfully built and run mpich 1.3.2 on our cluster. But since
>> we rather use bprsh (rsh like) between nodes, I have to specify the
>> bootstrap at mpiexec command line, like this:
>> mpiexec -bootstrap rsh -bootstrap-exec /usr/bin/bprsh
>> It works, but is there a way that I can make rsh as the default
>> bootstrap in some config file, so I don't have to specify that on every
>> mpiexec command?
>> I have tried to set HYDRA_BOOTSTRAP and HYDRA_BOOTSTRAP_EXEC environment
>> variables, that didn't work.
>> Thank you!
>> Limin
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
Type: text/x-diff
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110218/736da63e/attachment.bin>
