[mpich-discuss] How to config mpiexec use rsh as default bootstrap?
Steven Sutphen ssutphen at ualberta.ca
Sat Feb 19 13:54:12 CST 2011
Pavan,
I sent the the bsci_init.c.in file that I had patched by hand to Limin and it
worked for him--he has it running now. I hacked up the patch file that
you had sent to me--replacing the bsc_init.c.in portion with one that I
generated from the original and patched versions of the file.  The
"diff" command had different flags (as I was not using git) but I think
it will work.
I have attached that file as hydra_UA.patch.gz.
I also have attached my hand patched bsci_init.c.in file in case the patch
does not do the trick.
     steve.
On Sat, Feb 19, 2011 at 10:13 AM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> Hi Limin,
> On 02/18/2011 03:52 PM, Limin Gu wrote:
>> Is there a way I can get a patch based on v1.3.2?
> Unfortunately, this patch seems to have a bunch of other dependency patches.
> The 1.3.x nightly snapshot for Hydra should be quite stable
> (http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra/).
> Would you be able to use that in the meanwhile?
> We are discussing internally if we should pull forward the next release to
> fix these issues.
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110219/becaa85f/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110219/becaa85f/attachment-0001.bin>
