[mpich-discuss] MPICH2 config hangs
Dungan, Kerry kdungan at hpti.com
Thu Feb 17 12:41:01 CST 2011
updated c.txt with echo attached...
Here are the last comments before hanging:
checking for ANSI C header files... + test '' = set
+ cat
+ cat confdefs.h
+ cat
+ rm -f conftest.o
+ ac_try='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ case "(($ac_try" in
+ ac_try_echo='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ eval 'ac_try_echo="$as_me:24264: $CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5"'
++ ac_try_echo='configure:24264: gcc -c    -O2  -I/tmp/kdungan/mpich2-1.3.2p1/src/mpl/include -I/home/kdungan/libraries/mpich2-1.3.2p1/src/mpl/include -I/home/kdungan/libraries/mpich2-1.3.2p1/src/openpa/src -I/tmp/kdungan/mpich2-1.3.2p1/src/openpa/src conftest.c >&5'
+ printf '%s\n' 'configure:24264: gcc -c    -O2  -I/tmp/kdungan/mpich2-1.3.2p1/src/mpl/include -I/home/kdungan/libraries/mpich2-1.3.2p1/src/mpl/include -I/home/kdungan/libraries/mpich2-1.3.2p1/src/openpa/src -I/tmp/kdungan/mpich2-1.3.2p1/src/openpa/src conftest.c >&5'
+ ac_status=0
+ grep -v '^ *+' conftest.er1
+ rm -f conftest.er1
+ cat conftest.err
+ printf '%s\n' 'configure:24271: $? = 0'
+ exit 0
+ test -z ''
+ test -s conftest.o
+ ac_cv_header_stdc=yes
+ rm -f core conftest.err conftest.o conftest.c
+ test yes = yes
+ cat
+ cat confdefs.h
+ cat
+ memchr
Sent: Thursday, February 17, 2011 12:34 PM
To: Dungan, Kerry
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] MPICH2 config hangs
Can you add --enable-echo to your configure and send us the configure output ?
A.Chan
----- Original Message -----
> Setting gcc-4 was my attempt to solve the problem. The default gives
> the same problem.
> From: mpich-discuss-bounces at mcs.anl.gov
> [mpich-discuss-bounces at mcs.anl.gov] on behalf of Anthony Chan
> [chan at mcs.anl.gov]
> Sent: Thursday, February 17, 2011 11:17 AM
> To: mpich-discuss at mcs.anl.gov
> The ANSI C header test actually returns OK but configure just stops
> for
> no good reason. The test after the AC_HEADER_STDC looks for
> stddef.h(the
> same test returns OK earlier) but the record is in a different
> config.log.
> Is there any reason that you set CPP/CXXCPP to cpp-4 instead of
> letting configure
> looks for what it wants ?
> > During the configure phase of installing MPICH2 in cygwin, the tool
> > hangs at
> > The same command is successful two times earlier in the script.
> > c.txt
> > is attached.
> > Thanks,
> > Kerry E. Dungan, Ph.D.
> > Senior Staff Scientist
> > High-Performance Technologies, Inc.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110217/6c35ed62/attachment-0001.txt>
