[mpich-discuss] MPICH2 config hangs
Anthony Chan chan at mcs.anl.gov
Thu Feb 17 11:34:14 CST 2011
Can you add --enable-echo to your configure and send us the configure output ?
A.Chan
----- Original Message -----
> Setting gcc-4 was my attempt to solve the problem. The default gives
> the same problem.
> From: mpich-discuss-bounces at mcs.anl.gov
> [mpich-discuss-bounces at mcs.anl.gov] on behalf of Anthony Chan
> [chan at mcs.anl.gov]
> Sent: Thursday, February 17, 2011 11:17 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPICH2 config hangs
> The ANSI C header test actually returns OK but configure just stops
> for
> no good reason. The test after the AC_HEADER_STDC looks for
> stddef.h(the
> same test returns OK earlier) but the record is in a different
> config.log.
> Is there any reason that you set CPP/CXXCPP to cpp-4 instead of
> letting configure
> looks for what it wants ?
> > During the configure phase of installing MPICH2 in cygwin, the tool
> > hangs at
> > checking for ANSI C header files...
> > The same command is successful two times earlier in the script.
> > c.txt
> > is attached.
> > Thanks,
> > Kerry E. Dungan, Ph.D.
> > Senior Staff Scientist
> > High-Performance Technologies, Inc.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
