[mpich-discuss] MPICH2 config hangs
Anthony Chan chan at mcs.anl.gov
Thu Feb 17 13:27:42 CST 2011
I don't exactly know what went wrong.  AC_HEADER_STDC should trigger a test to look
for EGREP in mpich2's main configure.  But your c.txt indicates that the various
*GREP tests are not carried out before AC_HEADER_STDC in main configure.
For now, can you configure as follows:
configure --disable-f77 --disable-fc --enable-timer-type=gettimeofday ac_cv_path_EGREP="/usr/bin/grep -E" --prefix=....
Let us know if that works.
A.Chan
----- Original Message -----
> updated c.txt with echo attached...
> Here are the last comments before hanging:
> checking for ANSI C header files... + test '' = set
> + cat
> + cat confdefs.h
> + cat
> + rm -f conftest.o
> + ac_try='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
> + case "(($ac_try" in
> + ac_try_echo='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
> + eval 'ac_try_echo="$as_me:24264: $CC -c $CFLAGS $CPPFLAGS
> conftest.$ac_ext >&5"'
> ++ ac_try_echo='configure:24264: gcc -c -O2
> -I/tmp/kdungan/mpich2-1.3.2p1/src/mpl/include
> -I/home/kdungan/libraries/mpich2-1.3.2p1/src/mpl/include
> -I/home/kdungan/libraries/mpich2-1.3.2p1/src/openpa/src
> -I/tmp/kdungan/mpich2-1.3.2p1/src/openpa/src conftest.c >&5'
> + printf '%s\n' 'configure:24264: gcc -c -O2
> + ac_status=0
> + grep -v '^ *+' conftest.er1
> + rm -f conftest.er1
> + cat conftest.err
> + printf '%s\n' 'configure:24271: $? = 0'
> + exit 0
> + test -z ''
> + test -s conftest.o
> + ac_cv_header_stdc=yes
> + rm -f core conftest.err conftest.o conftest.c
> + test yes = yes
> + cat
> + cat confdefs.h
> + cat
> + memchr
> From: Anthony Chan [chan at mcs.anl.gov]
> Sent: Thursday, February 17, 2011 12:34 PM
> To: Dungan, Kerry
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPICH2 config hangs
> Can you add --enable-echo to your configure and send us the configure
> output ?
> A.Chan
> > Setting gcc-4 was my attempt to solve the problem. The default gives
> > the same problem.
> > From: mpich-discuss-bounces at mcs.anl.gov
> > [mpich-discuss-bounces at mcs.anl.gov] on behalf of Anthony Chan
> > Sent: Thursday, February 17, 2011 11:17 AM
> > To: mpich-discuss at mcs.anl.gov
> > The ANSI C header test actually returns OK but configure just stops
> > for
> > no good reason. The test after the AC_HEADER_STDC looks for
> > stddef.h(the
> > same test returns OK earlier) but the record is in a different
> > config.log.
> > Is there any reason that you set CPP/CXXCPP to cpp-4 instead of
> > letting configure
> > looks for what it wants ?
> > > During the configure phase of installing MPICH2 in cygwin, the
> > > tool
> > > hangs at
> > > The same command is successful two times earlier in the script.
> > > c.txt
> > > is attached.
> > > Thanks,
> > > Kerry E. Dungan, Ph.D.
> > > Senior Staff Scientist
> > > High-Performance Technologies, Inc.
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
