[mpich-discuss] MPICH2 config hangs
Dungan, Kerry kdungan at hpti.com
Thu Feb 17 11:01:52 CST 2011
Setting gcc-4 was my attempt to solve the problem.  The default gives the same problem.
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] on behalf of Anthony Chan [chan at mcs.anl.gov]
Sent: Thursday, February 17, 2011 11:17 AM
Subject: Re: [mpich-discuss] MPICH2 config hangs
The ANSI C header test actually returns OK but configure just stops for
no good reason.  The test after the AC_HEADER_STDC looks for stddef.h(the
same test returns OK earlier) but the record is in a different config.log.
Is there any reason that you set CPP/CXXCPP to cpp-4 instead of letting configure
looks for what it wants ?
----- Original Message -----
> During the configure phase of installing MPICH2 in cygwin, the tool
> hangs at
> checking for ANSI C header files...
> The same command is successful two times earlier in the script. c.txt
> is attached.
> Thanks,
> Kerry E. Dungan, Ph.D.
> Senior Staff Scientist
> High-Performance Technologies, Inc.
> mpich-discuss mailing list
