[mpich-discuss] 'make testing' fails on a pvfs2 filesystem.
전경원 kwchun at gist.ac.kr
Mon Feb 14 22:33:18 CST 2011
Hi.
I attached the test result of 'src'mpi/romio/'. It seems that the failed
tests are related with the shared file pointer and ordered mode. This time,
I used gfortran-4.3 for the Fortran compiler(i.e. F77=/usr/bin/gfortran
FC=/usr/bin/gfortran ./configure --with-file-system="pvfs2+nfs+ufs"). Other
configurations are the same.
Best regards.
2011/2/14 Rob Latham <robl at mcs.anl.gov>
> On Mon, Feb 14, 2011 at 09:23:36PM +0900, 전경원 wrote:
> > Hi.
> > I installed pvfs2-2.8.3 and mpich2-1.3.2 on Debian 5.0.6. Our pvfs2
> > installation was verified using pvfs2-{ping,cp,ls} as mentioned in the
> > manual. Also, mpich2 installation passed the 'make testing' verification
> on
> > the nfs filesystem. But, the io section of 'make teting' procedure, fails
> on
> > pvfs2 filesystem. Only four tests:
> > test/mpi/io{getextent,i_noncontig,async,userioerr}, passed without error.
> > Even more test/mpi/io/async_any produces error messages on the
> > pvfs2-server.log as:
> thanks for the bug report and the log.
> There are some MPI-IO features that are not supported on PVFS:
> - Shared file pointers requre explicit file locks, which PVFS does not
>  suport
> - Orderd mode also relies on the shared file pointer, so that's not
>  supported either
> Can you try out the tests in 'src/mpi/romio' ?   you can just do a
> "runtests -fname=/pvfs/whatever"
> For the async I/O test we might have to get the orangefs guys
> involved.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110215/ffe194cf/attachment.htm>
Type: application/x-bzip2
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110215/ffe194cf/attachment.bin>
