[mpich-discuss] MPICH 2 on Window 7 home premium
Koh Voon Li kohvoonli at gmail.com
Mon Feb 14 01:10:54 CST 2011
I have tried to run the example application cpi.exe and here is the error
message I got:
D:>mpiexec -hosts 2 WIN7-PC 1 user-PC 1 cpi
job aborted:
process: node: exit code: error message:
0: localhost: 13: Fatal error in MPI_Init:
MPI_Init(138).............: MPI_Init(argc_p=0x000000000012FE2C,
                            argv_p=0x000000000012FDB8) failed
MPIR_Init_thread(329).....: Initialization failed
MPID_Init(6514)...........: channel initialization failed
MPIDI_CH3_Init(215).......:
MPIDI_PG_SetConnInfo(5301): PMI_KVS_Put returned -1, Invalid KVS name
job aborted:
D:\>
This is what i got when I tried to run on localhost
*D:\>mpiexec -n 6 cpi.exe*
*job aborted:*
*process: node: exit code: error message:*
*0: localhost: 13: Fatal error in MPI_Init:*
*MPI_Init(138).............: MPI_Init(argc_p=0x000000000012FE2C,*
*                            argv_p=0x000000000012FDB8) failed*
*MPIR_Init_thread(329).....: Initialization failed*
*MPID_Init(6514)...........: channel initialization failed*
*MPIDI_CH3_Init(215).......:*
*MPIDI_PG_SetConnInfo(5301): PMI_KVS_Put returned -1, Invalid KVS name*
*job aborted:*
*job aborted:*
*job aborted:*
*job aborted:*
*job aborted:*
*D:\>*
Thanks.
Koh
On Mon, Feb 14, 2011 at 12:34 PM, Koh Voon Li <kohvoonli at gmail.com> wrote:
> Hi,
> I don't have any compiler with me on this computer. I found that after
> 1.2.1p1 is 1.3.1 which I found there was an issue for FDS to run correctly
> after 1.2. Any other ways can I get cpi.exe file?
> Thanks.
> Regards,
> Koh
> On Mon, Feb 14, 2011 at 12:00 PM, Jayesh Krishna <jayesh at mcs.anl.gov>wrote:
>> Hi,
>>  The examples might have been added after 1.2.1p1. You can get cpi.c from
>> https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/cpi.c .
>> Regards,
>> Jayesh
>> ----- Original Message -----
>> From: "Koh Voon Li" <kohvoonli at gmail.com>
>> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
>> Cc: mpich-discuss at mcs.anl.gov
>> Sent: Sunday, February 13, 2011 9:25:36 PM
>> Subject: Re: MPICH 2 on Window 7 home premium
>> Hi,
>> I didn't see any example folder under my MPICH2 directory. My version of
>> MPICH2 is mpich2-1.2.1p1 as I found that the latest version mpich2-1.3.1 did
>> not worked for FDS5. Where can I possibly find the cpi application?
>> Thanks.
>> Regards,
>> Koh
>> On Mon, Feb 14, 2011 at 11:16 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
>> wrote:
>> Hi,
>> The error could be related to the file not being found. You might want to
>> post the issue in the fds5 users list.
>> Meanwhile are you able to run cpi.exe (c:\Program
>> Files\MPICH2\examples\cpi.exe) in your cluster ?
>> Regards,
>> Jayesh
>> From: "Koh Voon Li" < kohvoonli at gmail.com >
>> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
>> Sent: Sunday, February 13, 2011 8:48:08 PM
>> Hi,
>> Thanks Jayesh, it seem work for me now. Here is the message I got by
>> running a simple command.
>> C:\>mpiexec -hosts 2 WIN7-PC 3 user-PC 3 c:\program files
>> \fds\fds5\bin\fds5_mpi_win_64.exe
>> Process 2 of 5 is running on WIN7-PC
>> Process 1 of 5 is running on WIN7-PC
>> Process 5 of 5 is running on user-PC
>> Process 0 of 5 is running on WIN7-PC
>> Process 4 of 5 is running on user-PC
>> Process 3 of 5 is running on user-PC
>> Fire Dynamics Simulator
>> Version: 5.5.3; MPI Enabled; OpenMP Disabled
>> SVN Revision Number: 7031
>> Compile Date: Fri, 29 Oct 2010
>> Consult FDS Users Guide Chapter, Running FDS, for further instructions.
>> Hit Enter to Escape...
>> job aborted:
>> rank: node: exit code[: error message]
>> 0: WIN7-PC: 123
>> 1: WIN7-PC: 0: process 1 exited without calling finalize
>> 2: WIN7-PC: 0: process 2 exited without calling finalize
>> 3: user-PC: 0: process 3 exited without calling finalize
>> 4: user-PC: 0: process 4 exited without calling finalize
>> 5: user-PC: 0: process 5 exited without calling finalize
>> But when I tried to run a job, I got error message as below:
>> D:\>mpiexec -hosts 2 WIN7-PC 3 user-PC 3 "c:\program
>> files\fds\fds5\bin\fds5_mpi
>> _win_64.exe" "\\WIN7-PC\Project\Paradigm\FDS\V16\paradigmv4-16.fds"
>> Mesh 1 is assigned to Process 0
>> Mesh 2 is assigned to Process 1
>> Mesh 3 is assigned to Process 2
>> Mesh 4 is assigned to Process 3
>> Mesh 5 is assigned to Process 3
>> Mesh 6 is assigned to Process 4
>> Mesh 7 is assigned to Process 5
>> forrtl: severe (29): file not found, unit 4, file
>> C:\Windows\system32\Paradigmv4
>> -16.smv
>> Image PC Routine Line Source
>> fds5_mpi_win_64.e 0000000140589BE8 Unknown Unknown Unknown
>> fds5_mpi_win_64.e 0000000140584CC9 Unknown Unknown Unknown
>> fds5_mpi_win_64.e 000000014053CA3D Unknown Unknown Unknown
>> fds5_mpi_win_64.e 000000014051AE17 Unknown Unknown Unknown
>> fds5_mpi_win_64.e 000000014051A6E1 Unknown Unknown Unknown
>> fds5_mpi_win_64.e 00000001404EB76F Unknown Unknown Unknown
>> fds5_mpi_win_64.e 00000001402FFF2D Unknown Unknown Unknown
>> fds5_mpi_win_64.e 00000001404A8E58 Unknown Unknown Unknown
>> fds5_mpi_win_64.e 000000014059338C Unknown Unknown Unknown
>> fds5_mpi_win_64.e 000000014056C055 Unknown Unknown Unknown
>> kernel32.dll 000000007725F56D Unknown Unknown Unknown
>> ntdll.dll 0000000077392CC1 Unknown Unknown Unknown
>> Fatal error in PMPI_Barrier: Other MPI error, error stack:
>> PMPI_Barrier(476).........................: MPI_Barrier(MPI_COMM_WORLD)
>> failed
>> MPIR_Barrier(82)..........................:
>> MPIC_Sendrecv(164)........................:
>> MPIC_Wait(513)............................:
>> MPIDI_CH3i_Progress_wait(215).............: an error occurred while
>> handling an
>> event returned by MPIDU_Sock_Wait()
>> MPIDI_CH3I_Progress_handle_sock_event(420):
>> MPIDU_Sock_wait(2606).....................: The specified network name is
>> no lon
>> ger available. (errno 64)
>> failed
>> handling an
>> no lon
>> job aborted:
>> 0: WIN7-PC: 123
>> 1: WIN7-PC: 123
>> 2: WIN7-PC: 123
>> 3: user-PC: 29: process 3 exited without calling finalize
>> 4: user-PC: 123: Fatal error in PMPI_Barrier: Other MPI error, error
>> stack:
>> failed
>> handling an
>> no lon
>> 5: user-PC: 123: Fatal error in PMPI_Barrier: Other MPI error, error
>> stack:
>> failed
>> handling an
>> no lon
>> Is it something has to do with my working directory? As I noticed 1 of the
>> error message I got as highlighted in yellow above said file not found on my
>> Window directory.
>> Thanks.
>> Regards,
>> Koh
>> On Sat, Feb 12, 2011 at 10:48 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>> wrote:
>> Hi,
>> Yes, you need to have the same username/password on both the machines (Or
>> use a domain user).
>> Let us know if it works.
>> Regards,
>> Jayesh
>> Sent: Friday, February 11, 2011 7:00:17 PM
>> Hi,
>> Thanks for the replies. The Windows username and password are different
>> between two machine. Do I need to create the same username & password
>> between them so that I able to get access between it?
>> Thanks.
>> Regards,
>> Koh
>> On Fri, Feb 11, 2011 at 9:26 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>> wrote:
>> Hi,
>> Do you have the same Windows username/password on both the machines ?
>> Regards,
>> Jayesh
>> Sent: Thursday, February 10, 2011 7:59:38 PM
>> Yes. I able registered on both machine. But when I tried to just launch
>> simply command I got error message as stated below:
>> C:\>mpiexec -hosts 2 WIN7-PC 1 user-PC 1 "c:\program
>> _win_64.exe"
>> abort: Unable to connect to user-PC
>> For your information, I have turned off both Window firewall. But still
>> failed to launch any job.
>> On Thu, Feb 10, 2011 at 11:52 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>> wrote:
>> Hi,
>> Is the username/password valid on the second machine (Do you have the same
>> Windows username/password on the second machine ? )? If so, you should be
>> able to run your job. Are you able to run your job now ?
>> Registration of username/password is local to the machine. MPICH2 does not
>> automatically register the same username on all the nodes. If you would like
>> to register username/password on each machine you should register the
>> credentials on each (Type "mpiexec -register" on each). However, to launch
>> your job you need to have the username/password registered only on the
>> machine/node where you launch your job.
>> Let us know the results.
>> Regards,
>> Jayesh
>> Sent: Thursday, February 10, 2011 9:30:16 AM
>> Hi,
>> Thanks for the reply. I was able to registered 2 username on 1 of my
>> computer, but I got error message on my 2nd computer when I try to validate
>> user on it.
>> Here is the error message.
>> FAIL: Unable to read the credentials from the registry.
>> Thanks,
>> Regards,
>> KOH
>> On Thu, Feb 10, 2011 at 10:10 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
>> wrote:
>> Hi,
>> >> Credentials for USER-PC\WIN 7 rejected connecting to user-PC
>> >> Aborting: Unable to connect to user-PC
>> From the error message it looks like you haven't registered a valid
>> username/password with mpiexec. Please register a valid Windows
>> username/password with mpiexec using the "-register" option (Type "mpiexec
>> -register" at the command prompt and mpiexec will prompt you for the
>> username/password). Once the registration is complete validate it using the
>> "-validate" option (Type "mpiexec -validate" at the command prompt). If you
>> have registered a valid Windows username/password the validate option should
>> return SUCCESS.
>> Regards,
>> Jayesh
>> To: jayesh at mcs.anl.gov
>> Sent: Thursday, February 10, 2011 2:59:35 AM
>> Subject: Fwd: MPICH 2 on Window 7 home premium
>> Hi Jayesh,
>> Sorry for bothering. Attached here is the smpd log in debug mode.
>> Million Thanks.
>> Regards,
>> KOH
>> ---------- Forwarded message ----------
>> From: Koh Voon Li < kohvoonli at gmail.com >
>> Date: Thu, Feb 10, 2011 at 3:30 PM
>> Subject: MPICH 2 on Window 7 home premium
>> Hi Jayesh,
>> I am trying to running parallel FDS (Fire Dynamic Simulator) via 2 PC by
>> using a config file
>> here is my config file
>> exe "C:\Program Files\FDS\FDS5\bin\fds5_mpi_win_64.exe"
>> "ParadigmV4-13.fds"
>> wdir "\\USER-PC\Project\Paradigm\"
>> hosts
>> user-PC 6
>> WIN7-PC 6
>> This is the error message I got from the command prompt.
>> C:\>mpiexec -file config.txt
>> I used a cross over cable to connect both PCs and I think my setting for
>> the IP address is correct as I can ping each other computer in the command
>> prompt.
>> I tried to turned off both firewall but it failed.
>> Thanks,
>> Regards,
>> Koh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110214/6c6d345e/attachment-0001.htm>
