[mpich-discuss] MPICH 2 on Window 7 home premium
Koh Voon Li kohvoonli at gmail.com
Sun Feb 13 22:34:02 CST 2011
I don't have any compiler with me on this computer. I found that after
1.2.1p1 is 1.3.1 which I found there was an issue for FDS to run correctly
after 1.2. Any other ways can I get cpi.exe file?
Thanks.
Koh
On Mon, Feb 14, 2011 at 12:00 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  The examples might have been added after 1.2.1p1. You can get cpi.c from
> https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/cpi.c .
> Regards,
> Jayesh
> From: "Koh Voon Li" <kohvoonli at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Sunday, February 13, 2011 9:25:36 PM
> Subject: Re: MPICH 2 on Window 7 home premium
> Hi,
> I didn't see any example folder under my MPICH2 directory. My version of
> MPICH2 is mpich2-1.2.1p1 as I found that the latest version mpich2-1.3.1 did
> not worked for FDS5. Where can I possibly find the cpi application?
> Thanks.
> Regards,
> Koh
> On Mon, Feb 14, 2011 at 11:16 AM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> The error could be related to the file not being found. You might want to
> post the issue in the fds5 users list.
> Meanwhile are you able to run cpi.exe (c:\Program
> Files\MPICH2\examples\cpi.exe) in your cluster ?
> Regards,
> Jayesh
> From: "Koh Voon Li" < kohvoonli at gmail.com >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> Sent: Sunday, February 13, 2011 8:48:08 PM
> Hi,
> Thanks Jayesh, it seem work for me now. Here is the message I got by
> running a simple command.
> C:\>mpiexec -hosts 2 WIN7-PC 3 user-PC 3 c:\program files
> \fds\fds5\bin\fds5_mpi_win_64.exe
> Process 2 of 5 is running on WIN7-PC
> Process 1 of 5 is running on WIN7-PC
> Process 5 of 5 is running on user-PC
> Process 0 of 5 is running on WIN7-PC
> Process 4 of 5 is running on user-PC
> Process 3 of 5 is running on user-PC
> Fire Dynamics Simulator
> Version: 5.5.3; MPI Enabled; OpenMP Disabled
> SVN Revision Number: 7031
> Compile Date: Fri, 29 Oct 2010
> Consult FDS Users Guide Chapter, Running FDS, for further instructions.
> Hit Enter to Escape...
> job aborted:
> rank: node: exit code[: error message]
> 0: WIN7-PC: 123
> 1: WIN7-PC: 0: process 1 exited without calling finalize
> 2: WIN7-PC: 0: process 2 exited without calling finalize
> 3: user-PC: 0: process 3 exited without calling finalize
> 4: user-PC: 0: process 4 exited without calling finalize
> 5: user-PC: 0: process 5 exited without calling finalize
> But when I tried to run a job, I got error message as below:
> D:\>mpiexec -hosts 2 WIN7-PC 3 user-PC 3 "c:\program
> files\fds\fds5\bin\fds5_mpi
> _win_64.exe" "\\WIN7-PC\Project\Paradigm\FDS\V16\paradigmv4-16.fds"
> Mesh 1 is assigned to Process 0
> Mesh 2 is assigned to Process 1
> Mesh 3 is assigned to Process 2
> Mesh 4 is assigned to Process 3
> Mesh 5 is assigned to Process 3
> Mesh 6 is assigned to Process 4
> Mesh 7 is assigned to Process 5
> forrtl: severe (29): file not found, unit 4, file
> C:\Windows\system32\Paradigmv4
> -16.smv
> Image PC Routine Line Source
> fds5_mpi_win_64.e 0000000140589BE8 Unknown Unknown Unknown
> fds5_mpi_win_64.e 0000000140584CC9 Unknown Unknown Unknown
> fds5_mpi_win_64.e 000000014053CA3D Unknown Unknown Unknown
> fds5_mpi_win_64.e 000000014051AE17 Unknown Unknown Unknown
> fds5_mpi_win_64.e 000000014051A6E1 Unknown Unknown Unknown
> fds5_mpi_win_64.e 00000001404EB76F Unknown Unknown Unknown
> fds5_mpi_win_64.e 00000001402FFF2D Unknown Unknown Unknown
> fds5_mpi_win_64.e 00000001404A8E58 Unknown Unknown Unknown
> fds5_mpi_win_64.e 000000014059338C Unknown Unknown Unknown
> fds5_mpi_win_64.e 000000014056C055 Unknown Unknown Unknown
> kernel32.dll 000000007725F56D Unknown Unknown Unknown
> ntdll.dll 0000000077392CC1 Unknown Unknown Unknown
> Fatal error in PMPI_Barrier: Other MPI error, error stack:
> PMPI_Barrier(476).........................: MPI_Barrier(MPI_COMM_WORLD)
> failed
> MPIR_Barrier(82)..........................:
> MPIC_Sendrecv(164)........................:
> MPIC_Wait(513)............................:
> MPIDI_CH3i_Progress_wait(215).............: an error occurred while
> handling an
> event returned by MPIDU_Sock_Wait()
> MPIDI_CH3I_Progress_handle_sock_event(420):
> MPIDU_Sock_wait(2606).....................: The specified network name is
> no lon
> ger available. (errno 64)
> failed
> handling an
> no lon
> job aborted:
> 0: WIN7-PC: 123
> 1: WIN7-PC: 123
> 2: WIN7-PC: 123
> 3: user-PC: 29: process 3 exited without calling finalize
> 4: user-PC: 123: Fatal error in PMPI_Barrier: Other MPI error, error stack:
> failed
> handling an
> no lon
> 5: user-PC: 123: Fatal error in PMPI_Barrier: Other MPI error, error stack:
> failed
> handling an
> no lon
> Is it something has to do with my working directory? As I noticed 1 of the
> error message I got as highlighted in yellow above said file not found on my
> Window directory.
> Thanks.
> Regards,
> Koh
> On Sat, Feb 12, 2011 at 10:48 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Yes, you need to have the same username/password on both the machines (Or
> use a domain user).
> Let us know if it works.
> Regards,
> Jayesh
> Sent: Friday, February 11, 2011 7:00:17 PM
> Hi,
> Thanks for the replies. The Windows username and password are different
> between two machine. Do I need to create the same username & password
> between them so that I able to get access between it?
> Thanks.
> Regards,
> Koh
> On Fri, Feb 11, 2011 at 9:26 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Do you have the same Windows username/password on both the machines ?
> Regards,
> Jayesh
> Sent: Thursday, February 10, 2011 7:59:38 PM
> Yes. I able registered on both machine. But when I tried to just launch
> simply command I got error message as stated below:
> C:\>mpiexec -hosts 2 WIN7-PC 1 user-PC 1 "c:\program
> _win_64.exe"
> abort: Unable to connect to user-PC
> For your information, I have turned off both Window firewall. But still
> failed to launch any job.
> On Thu, Feb 10, 2011 at 11:52 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Is the username/password valid on the second machine (Do you have the same
> Windows username/password on the second machine ? )? If so, you should be
> able to run your job. Are you able to run your job now ?
> Registration of username/password is local to the machine. MPICH2 does not
> automatically register the same username on all the nodes. If you would like
> to register username/password on each machine you should register the
> credentials on each (Type "mpiexec -register" on each). However, to launch
> your job you need to have the username/password registered only on the
> machine/node where you launch your job.
> Let us know the results.
> Regards,
> Jayesh
> Sent: Thursday, February 10, 2011 9:30:16 AM
> Hi,
> Thanks for the reply. I was able to registered 2 username on 1 of my
> computer, but I got error message on my 2nd computer when I try to validate
> user on it.
> Here is the error message.
> FAIL: Unable to read the credentials from the registry.
> Thanks,
> Regards,
> KOH
> On Thu, Feb 10, 2011 at 10:10 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> >> Credentials for USER-PC\WIN 7 rejected connecting to user-PC
> >> Aborting: Unable to connect to user-PC
> From the error message it looks like you haven't registered a valid
> username/password with mpiexec. Please register a valid Windows
> username/password with mpiexec using the "-register" option (Type "mpiexec
> -register" at the command prompt and mpiexec will prompt you for the
> username/password). Once the registration is complete validate it using the
> "-validate" option (Type "mpiexec -validate" at the command prompt). If you
> have registered a valid Windows username/password the validate option should
> return SUCCESS.
> Regards,
> Jayesh
> To: jayesh at mcs.anl.gov
> Sent: Thursday, February 10, 2011 2:59:35 AM
> Subject: Fwd: MPICH 2 on Window 7 home premium
> Hi Jayesh,
> Sorry for bothering. Attached here is the smpd log in debug mode.
> Million Thanks.
> Regards,
> KOH
> ---------- Forwarded message ----------
> From: Koh Voon Li < kohvoonli at gmail.com >
> Date: Thu, Feb 10, 2011 at 3:30 PM
> Subject: MPICH 2 on Window 7 home premium
> Hi Jayesh,
> I am trying to running parallel FDS (Fire Dynamic Simulator) via 2 PC by
> using a config file
> here is my config file
> exe "C:\Program Files\FDS\FDS5\bin\fds5_mpi_win_64.exe" "ParadigmV4-13.fds"
> wdir "\\USER-PC\Project\Paradigm\"
> hosts
> user-PC 6
> WIN7-PC 6
> This is the error message I got from the command prompt.
> C:\>mpiexec -file config.txt
> I used a cross over cable to connect both PCs and I think my setting for
> the IP address is correct as I can ping each other computer in the command
> prompt.
> I tried to turned off both firewall but it failed.
> Thanks,
> Regards,
> Koh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110214/9e705157/attachment.htm>
