[mpich-discuss] MPICH 2 on Window 7 home premium
Jayesh Krishna jayesh at mcs.anl.gov
Mon Feb 14 05:32:05 CST 2011
 Did you take cpi.exe from 1.3.1 ? You will have to recompile the program to use it with 1.2.1.
 The Microsoft Visual Studio Express editions should be available for free. You could also try installing Cygwin and using gcc from Cygwin to compile the code. If you are not able to compile an MPI program you might have better luck with your question from the fds user community.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, February 14, 2011 1:10:54 AM
Subject: Re: MPICH 2 on Window 7 home premium
I have tried to run the example application cpi.exe and here is the error message I got:
D:>mpiexec -hosts 2 WIN7-PC 1 user-PC 1 cpi
job aborted:
process: node: exit code: error message:
0: localhost: 13: Fatal error in MPI_Init:
MPI_Init(138).............: MPI_Init(argc_p=0x000000000012FE2C,
argv_p=0x000000000012FDB8) failed
MPIR_Init_thread(329).....: Initialization failed
MPID_Init(6514)...........: channel initialization failed
MPIDI_CH3_Init(215).......:
MPIDI_PG_SetConnInfo(5301): PMI_KVS_Put returned -1, Invalid KVS name
job aborted:
D:\>
This is what i got when I tried to run on localhost
D:\>mpiexec -n 6 cpi.exe
job aborted:
job aborted:
job aborted:
job aborted:
job aborted:
job aborted:
D:\>
Thanks.
Koh
On Mon, Feb 14, 2011 at 12:34 PM, Koh Voon Li < kohvoonli at gmail.com > wrote:
I don't have any compiler with me on this computer. I found that after 1.2.1p1 is 1.3.1 which I found there was an issue for FDS to run correctly after 1.2. Any other ways can I get cpi.exe file?
Thanks.
Koh
On Mon, Feb 14, 2011 at 12:00 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
The examples might have been added after 1.2.1p1. You can get cpi.c from https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/cpi.c .
Jayesh
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
Sent: Sunday, February 13, 2011 9:25:36 PM
I didn't see any example folder under my MPICH2 directory. My version of MPICH2 is mpich2-1.2.1p1 as I found that the latest version mpich2-1.3.1 did not worked for FDS5. Where can I possibly find the cpi application?
Thanks.
Koh
On Mon, Feb 14, 2011 at 11:16 AM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
The error could be related to the file not being found. You might want to post the issue in the fds5 users list.
Meanwhile are you able to run cpi.exe (c:\Program Files\MPICH2\examples\cpi.exe) in your cluster ?
Jayesh
Sent: Sunday, February 13, 2011 8:48:08 PM
Thanks Jayesh, it seem work for me now. Here is the message I got by running a simple command.
C:\>mpiexec -hosts 2 WIN7-PC 3 user-PC 3 c:\program files
\fds\fds5\bin\fds5_mpi_win_64.exe
Process 2 of 5 is running on WIN7-PC
Process 1 of 5 is running on WIN7-PC
Process 5 of 5 is running on user-PC
Process 0 of 5 is running on WIN7-PC
Process 4 of 5 is running on user-PC
Process 3 of 5 is running on user-PC
Fire Dynamics Simulator
Version: 5.5.3; MPI Enabled; OpenMP Disabled
SVN Revision Number: 7031
Compile Date: Fri, 29 Oct 2010
Consult FDS Users Guide Chapter, Running FDS, for further instructions.
Hit Enter to Escape...
job aborted:
rank: node: exit code[: error message]
0: WIN7-PC: 123
1: WIN7-PC: 0: process 1 exited without calling finalize
2: WIN7-PC: 0: process 2 exited without calling finalize
3: user-PC: 0: process 3 exited without calling finalize
4: user-PC: 0: process 4 exited without calling finalize
5: user-PC: 0: process 5 exited without calling finalize
But when I tried to run a job, I got error message as below:
D:\>mpiexec -hosts 2 WIN7-PC 3 user-PC 3 "c:\program files\fds\fds5\bin\fds5_mpi
_win_64.exe" "\\WIN7-PC\Project\Paradigm\FDS\V16\paradigmv4-16.fds"
Mesh 1 is assigned to Process 0
Mesh 2 is assigned to Process 1
Mesh 3 is assigned to Process 2
Mesh 4 is assigned to Process 3
Mesh 5 is assigned to Process 3
Mesh 6 is assigned to Process 4
Mesh 7 is assigned to Process 5
forrtl: severe (29): file not found, unit 4, file C:\Windows\system32\Paradigmv4
-16.smv
Image PC Routine Line Source
fds5_mpi_win_64.e 0000000140589BE8 Unknown Unknown Unknown
fds5_mpi_win_64.e 0000000140584CC9 Unknown Unknown Unknown
fds5_mpi_win_64.e 000000014053CA3D Unknown Unknown Unknown
fds5_mpi_win_64.e 000000014051AE17 Unknown Unknown Unknown
fds5_mpi_win_64.e 000000014051A6E1 Unknown Unknown Unknown
fds5_mpi_win_64.e 00000001404EB76F Unknown Unknown Unknown
fds5_mpi_win_64.e 00000001402FFF2D Unknown Unknown Unknown
fds5_mpi_win_64.e 00000001404A8E58 Unknown Unknown Unknown
fds5_mpi_win_64.e 000000014059338C Unknown Unknown Unknown
fds5_mpi_win_64.e 000000014056C055 Unknown Unknown Unknown
kernel32.dll 000000007725F56D Unknown Unknown Unknown
ntdll.dll 0000000077392CC1 Unknown Unknown Unknown
Fatal error in PMPI_Barrier: Other MPI error, error stack:
PMPI_Barrier(476).........................: MPI_Barrier(MPI_COMM_WORLD) failed
MPIR_Barrier(82)..........................:
MPIC_Sendrecv(164)........................:
MPIC_Wait(513)............................:
MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an
event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(420):
MPIDU_Sock_wait(2606).....................: The specified network name is no lon
ger available. (errno 64)
job aborted:
0: WIN7-PC: 123
1: WIN7-PC: 123
2: WIN7-PC: 123
3: user-PC: 29: process 3 exited without calling finalize
4: user-PC: 123: Fatal error in PMPI_Barrier: Other MPI error, error stack:
5: user-PC: 123: Fatal error in PMPI_Barrier: Other MPI error, error stack:
Is it something has to do with my working directory? As I noticed 1 of the error message I got as highlighted in yellow above said file not found on my Window directory.
Thanks.
Koh
On Sat, Feb 12, 2011 at 10:48 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Yes, you need to have the same username/password on both the machines (Or use a domain user).
Let us know if it works.
Jayesh
Sent: Friday, February 11, 2011 7:00:17 PM
Thanks for the replies. The Windows username and password are different between two machine. Do I need to create the same username & password between them so that I able to get access between it?
Thanks.
Koh
On Fri, Feb 11, 2011 at 9:26 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Do you have the same Windows username/password on both the machines ?
Jayesh
Sent: Thursday, February 10, 2011 7:59:38 PM
Yes. I able registered on both machine. But when I tried to just launch simply command I got error message as stated below:
C:\>mpiexec -hosts 2 WIN7-PC 1 user-PC 1 "c:\program files\fds\fds5\bin\fds5_mpi
_win_64.exe"
abort: Unable to connect to user-PC
For your information, I have turned off both Window firewall. But still failed to launch any job.
On Thu, Feb 10, 2011 at 11:52 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Is the username/password valid on the second machine (Do you have the same Windows username/password on the second machine ? )? If so, you should be able to run your job. Are you able to run your job now ?
Registration of username/password is local to the machine. MPICH2 does not automatically register the same username on all the nodes. If you would like to register username/password on each machine you should register the credentials on each (Type "mpiexec -register" on each). However, to launch your job you need to have the username/password registered only on the machine/node where you launch your job.
Let us know the results.
Jayesh
Sent: Thursday, February 10, 2011 9:30:16 AM
Thanks for the reply. I was able to registered 2 username on 1 of my computer, but I got error message on my 2nd computer when I try to validate user on it.
Here is the error message.
FAIL: Unable to read the credentials from the registry.
KOH
On Thu, Feb 10, 2011 at 10:10 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
>> Credentials for USER-PC\WIN 7 rejected connecting to user-PC
>> Aborting: Unable to connect to user-PC
>From the error message it looks like you haven't registered a valid username/password with mpiexec. Please register a valid Windows username/password with mpiexec using the "-register" option (Type "mpiexec -register" at the command prompt and mpiexec will prompt you for the username/password). Once the registration is complete validate it using the "-validate" option (Type "mpiexec -validate" at the command prompt). If you have registered a valid Windows username/password the validate option should return SUCCESS.
Jayesh
To: jayesh at mcs.anl.gov
Sent: Thursday, February 10, 2011 2:59:35 AM
Subject: Fwd: MPICH 2 on Window 7 home premium
Hi Jayesh,
Sorry for bothering. Attached here is the smpd log in debug mode.
Million Thanks.
KOH
---------- Forwarded message ----------
Date: Thu, Feb 10, 2011 at 3:30 PM
Subject: MPICH 2 on Window 7 home premium
Hi Jayesh,
I am trying to running parallel FDS (Fire Dynamic Simulator) via 2 PC by using a config file
here is my config file
exe "C:\Program Files\FDS\FDS5\bin\fds5_mpi_win_64.exe" "ParadigmV4-13.fds"
wdir "\\USER-PC\Project\Paradigm\"
hosts
user-PC 6
WIN7-PC 6
This is the error message I got from the command prompt.
C:\>mpiexec -file config.txt
I used a cross over cable to connect both PCs and I think my setting for the IP address is correct as I can ping each other computer in the command prompt.
I tried to turned off both firewall but it failed.
Koh
