[mpich-discuss] installation MPICH2
Jayesh Krishna jayesh at mcs.anl.gov
Thu Feb 10 08:05:20 CST 2011
 The MPICH2 installer basically copies the required libs/dlls/headers to appropriate locations and installs the process manager for you. You can perform these steps manually, however it is not preferred/supported since unless you know exactly what you are doing you can create a nightmare for yourself.
 There are multiple dlls (for different channels, fotran, mpe etc) installed by MPICH2 in your system. You will have to copy all the dlls to the other machine, install SMPD manually (making sure that you are installing the same version as of the dlls). Moreover unless you copy libs/headers/utils (of the same version as the dlls, SMPD etc) you won't be able to compile/run your program from a system.
 Is there any reason you don't want to use the installer ?
Jayesh
----- Original Message -----
From: "Valerio Martorelli" <v.martorelli at ids-spa.it>
Sent: Thursday, February 10, 2011 5:16:51 AM
Subject: Re: [mpich-discuss] installation MPICH2
Thanks for support,
I have installed MPICH2 on all machines and it works.
Nevertheless, I have tried to install the MPICH2 only on a single machine and to copy the MPICH2 dll (I am working on windows systems) and to install smpd on the other machine.
It seems to work correctly.
Is there some drawbacks in this case?
Valerio
Il 09/02/2011 16.22, Jayesh Krishna ha scritto:
 You should have MPICH2 installed on all the machines/nodes used for your MPI job.
 Let us know if you have any issues.
Jayesh
From: "Valerio Martorelli" <v.martorelli at ids-spa.it> To: mpich-discuss at mcs.anl.gov Sent: Wednesday, February 9, 2011 5:39:07 AM
Subject: [mpich-discuss] installation MPICH2
Dear all,
I have one question regarding the installation of MPICH2.
I have to set a cluster for running my code.
I have two machines. My question is: Do I have to install MPICH2 on both machines or is sufficient to install MPICH2 on the machine that launches mpiexec and put some dll on the other PC (in addition to the installation of SMPD) ?
Thanks in advance.
Valerio Martorelli
mpich-discuss mailing list mpich-discuss at mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
