[mpich-discuss] installation MPICH2
Valerio Martorelli v.martorelli at ids-spa.it
Thu Feb 10 05:16:51 CST 2011
Thanks for support,
I have installed MPICH2 on all machines and it works.
Nevertheless, I have tried to install the MPICH2 only on a single
machine and to copy the MPICH2 dll (I am working on windows systems) and
to install smpd on the other machine.
It seems to work correctly.
Is there some drawbacks in this case?
Valerio
Il 09/02/2011 16.22, Jayesh Krishna ha scritto:
> Hi,
>   You should have MPICH2 installed on all the machines/nodes used for your MPI job.
>   Let us know if you have any issues.
> Regards,
> Jayesh
> From: "Valerio Martorelli"<v.martorelli at ids-spa.it>
> To: mpich-discuss at mcs.anl.gov
> Sent: Wednesday, February 9, 2011 5:39:07 AM
> Subject: [mpich-discuss] installation MPICH2
> Dear all,
> I have one question regarding the installation of MPICH2.
> I have to set a cluster for running my code.
> I have two machines. My question is: Do I have to install MPICH2 on both machines or is sufficient to install MPICH2 on the machine that launches mpiexec and put some dll on the other PC (in addition to the installation of SMPD) ?
> Thanks in advance.
> Valerio Martorelli
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110210/4167b294/attachment-0001.htm>
