[mpich-discuss] UNUSUAL MPICH-2 ERROR
Jeff Hammond jhammond at alcf.anl.gov
Tue Dec 13 07:04:16 CST 2011
You should not install have to install MPICH2 on any Blue Gene system.
 Please look in /bgsys/drivers/ppcfloor/comm/bin/ for the mpi*
compiler wrapper scripts.  If they are not present, please follow the
IBM documentation on how to install the system software via RPM.  Do
not try to install MPI on a Blue Gene by downloading the latest
MPICH2.
Jeff
On Tue, Dec 13, 2011 at 6:30 AM, Sticks Mabakane <smabakane at csir.co.za> wrote:
> Dear Mpich-2,
> I am an administrator of Blue Gene system and currently trying to install
> mpich-2. I have successfully installed mpich-2 without any errors. However;
> when i try to run the DL_POLY application using mpich-2 is giving the
> following error:
> mpiexec at chpcsn] HYD_pmcd_pmi_alloc_pg_scratch
> (./pm/pmiserv/pmiserv_utils.c:595): assert (pg->pg_process_count *
> sizeof(struct HYD_pmcd_pmi_ecount)) failed
> [mpiexec at chpcsn] HYD_pmci_launch_procs (./pm/pmiserv/pmiserv_pmci.c:103):
> error allocating pg scratch space
> [mpiexec at chpcsn] main (./ui/mpich/mpiexec.c:401): process manager returned
> error launching processes
> I have also tried to issue the command: mpirun --help and it showed the same
> error message as follows:
> chpcsn:/bgsys/drivers/ppcfloor/bin # /bgsys/drivers/ppcfloor/bin/mpirun
> --help
> [mpiexec at chpcsn] HYDU_parse_array (./utils/args/args.c:137):
> [mpiexec at chpcsn] parse_args (./ui/mpich/utils.c:1387): error parsing input
> array
> [mpiexec at chpcsn] HYD_uii_mpx_get_parameters (./ui/mpich/utils.c:1438):
> unable to parse user arguments
> Usage: ./mpiexec [global opts] [exec1 local opts] : [exec2 local opts] : ...
> Global options (passed to all executables):
>   Global environment options:
>     -genv {name} {value}             environment variable name and value
>     -genvlist {env1,env2,...}        environment variable list to pass
>     -genvnone                        do not pass any environment variables
>     -genvall                         pass all environment variables not
> managed
>                                           by the launcher (default)
> Mpich-2 was compiled using gcc-4.1.2 and G Fortran 95. Blue Gene system is
> running: Linux PowerPC. Please receive an attached config.log file.
> Regards,
> Sticks
> This message is subject to the CSIR's copyright terms and conditions, e-mail
> legal notice, and implemented Open Document Format (ODF) standard.
> The full disclaimer details can be found at
> http://www.csir.co.za/disclaimer.html.
> This message has been scanned for viruses and dangerous content by
> MailScanner,
> and is believed to be clean.
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki-old.alcf.anl.gov/index.php/User:Jhammond
