[mpich-discuss] UNUSUAL MPICH-2 ERROR
Sticks Mabakane SMabakane at csir.co.za
Tue Dec 13 07:31:20 CST 2011
Dear Jeff,
We are currently moving our Blue Gene system from Loadleveler resource manager to Moab Scheduling system. The Moab is currently running very well with Slurm in Blue Gene but the problem is the mpi. Unfortunately; all the mpi wrappers in /bgsys/drivers/ppcfloor/comm/bin/ were compiled against Loadleveler libraries. Is there any Blue Gene documentation that you think it may help me?
Sticks
>>> Jeff Hammond <jhammond at alcf.anl.gov> 13/12/2011 15:04 >>>
You should not install have to install MPICH2 on any Blue Gene system.
Please look in /bgsys/drivers/ppcfloor/comm/bin/ for the mpi*
compiler wrapper scripts.  If they are not present, please follow the
IBM documentation on how to install the system software via RPM.  Do
not try to install MPI on a Blue Gene by downloading the latest
MPICH2.
Jeff
On Tue, Dec 13, 2011 at 6:30 AM, Sticks Mabakane <smabakane at csir.co.za> wrote:
> Dear Mpich-2,
> I am an administrator of Blue Gene system and currently trying to install
> mpich-2. I have successfully installed mpich-2 without any errors. However;
> when i try to run the DL_POLY application using mpich-2 is giving the
> following error:
> mpiexec at chpcsn] HYD_pmcd_pmi_alloc_pg_scratch
> (./pm/pmiserv/pmiserv_utils.c:595): assert (pg->pg_process_count *
> sizeof(struct HYD_pmcd_pmi_ecount)) failed
> [mpiexec at chpcsn] HYD_pmci_launch_procs (./pm/pmiserv/pmiserv_pmci.c:103):
> error allocating pg scratch space
> [mpiexec at chpcsn] main (./ui/mpich/mpiexec.c:401): process manager returned
> error launching processes
> I have also tried to issue the command: mpirun --help and it showed the same
> error message as follows:
> chpcsn:/bgsys/drivers/ppcfloor/bin # /bgsys/drivers/ppcfloor/bin/mpirun
> --help
> [mpiexec at chpcsn] HYDU_parse_array (./utils/args/args.c:137):
> [mpiexec at chpcsn] parse_args (./ui/mpich/utils.c:1387): error parsing input
> array
> [mpiexec at chpcsn] HYD_uii_mpx_get_parameters (./ui/mpich/utils.c:1438):
> unable to parse user arguments
> Usage: ./mpiexec [global opts] [exec1 local opts] : [exec2 local opts] : ...
> Global options (passed to all executables):
>   Global environment options:
>     -genv {name} {value}             environment variable name and value
>     -genvlist {env1,env2,...}        environment variable list to pass
>     -genvnone                        do not pass any environment variables
>     -genvall                         pass all environment variables not
> managed
>                                           by the launcher (default)
> Mpich-2 was compiled using gcc-4.1.2 and G Fortran 95. Blue Gene system is
> running: Linux PowerPC. Please receive an attached config.log file.
> Regards,
> Sticks
> This message is subject to the CSIR's copyright terms and conditions, e-mail
> legal notice, and implemented Open Document Format (ODF) standard.
> The full disclaimer details can be found at
> http://www.csir.co.za/disclaimer.html.
> This message has been scanned for viruses and dangerous content by
> MailScanner,
> and is believed to be clean.
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki-old.alcf.anl.gov/index.php/User:Jhammond
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111213/048221a0/attachment.htm>
