[mpich-discuss] UNUSUAL MPICH-2 ERROR
Sticks Mabakane smabakane at csir.co.za
Tue Dec 13 06:30:22 CST 2011
Dear Mpich-2,
I am an administrator of Blue Gene system and currently trying to install mpich-2. I have successfully installed mpich-2 without any errors. However; when i try to run the DL_POLY application using mpich-2 is giving the following error:
mpiexec at chpcsn] HYD_pmcd_pmi_alloc_pg_scratch (./pm/pmiserv/pmiserv_utils.c:595): assert (pg->pg_process_count * sizeof(struct HYD_pmcd_pmi_ecount)) failed
[mpiexec at chpcsn] HYD_pmci_launch_procs (./pm/pmiserv/pmiserv_pmci.c:103): error allocating pg scratch space
[mpiexec at chpcsn] main (./ui/mpich/mpiexec.c:401): process manager returned error launching processes
I have also tried to issue the command: mpirun --help and it showed the same error message as follows:
chpcsn:/bgsys/drivers/ppcfloor/bin # /bgsys/drivers/ppcfloor/bin/mpirun --help
[mpiexec at chpcsn] HYDU_parse_array (./utils/args/args.c:137): [mpiexec at chpcsn] parse_args (./ui/mpich/utils.c:1387): error parsing input array
[mpiexec at chpcsn] HYD_uii_mpx_get_parameters (./ui/mpich/utils.c:1438): unable to parse user arguments
Usage: ./mpiexec [global opts] [exec1 local opts] : [exec2 local opts] : ...
Global options (passed to all executables):
  Global environment options:
    -genv {name} {value}             environment variable name and value
    -genvlist {env1,env2,...}        environment variable list to pass
    -genvnone                        do not pass any environment variables
    -genvall                         pass all environment variables not managed
                                          by the launcher (default)
Mpich-2 was compiled using gcc-4.1.2 and G Fortran 95. Blue Gene system is running: Linux PowerPC. Please receive an attached config.log file.
Sticks
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111213/b0665213/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111213/b0665213/attachment-0001.obj>
