[mpich-discuss] MPICH2 1.3: Problem with building several acrchitectrues from same source directory
Reuti reuti at staff.uni-marburg.de
Mon Oct 25 16:15:20 CDT 2010
why not build in two different directories? You don't have to untar
the source tree twice, but create two directories on the same level
where you untarred MPICH2 like "mpich2-32" and "mpich2-64" and after
changing into each of them you execute "../mpich2-1.3/configure ...
32flags..." resp. in the other directory for 64 bits.
-- Reuti
Am 25.10.2010 um 22:46 schrieb Yauheni Zelenko <zelenko at cadence.com>:
> Hi!
> I download MPICH2 1.3 and build 32 and 64 bits Linux versions from
> same source directory. Sure, I did ./configure for architecture
> change.
> Builds are failed on examples directory on cpi because existing
> object file (cpi.o) are inconsistent with current architecture. It's
> only example which are built. make clean also didn't remove existing
> object. So it's necessary to remove it manually
> I didn't encounter this problem with 1.3rc1 and early development
> builds.
> I think will be good idea if somebody with Automake expertise will
> look into this problem.
> Eugene.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
