[mpich-discuss] MPICH2 1.3: Problem with building several acrchitectrues from same source directory
Dave Goodell goodell at mcs.anl.gov
Mon Oct 25 16:21:24 CDT 2010
On Oct 25, 2010, at 3:46 PM CDT, Yauheni Zelenko wrote:
> Builds are failed on examples directory on cpi because existing object file (cpi.o) are inconsistent with current architecture. It's only example which are built. make clean also didn't remove existing object. So it's necessary to remove it manually
Thanks for letting us know.  I just fixed this on the trunk: https://trac.mcs.anl.gov/projects/mpich2/changeset/7375
> I didn't encounter this problem with 1.3rc1 and early development builds.
I'm surprised you didn't experience this with the pre-releases, since they should have had this problem as well...
-Dave
