[mpich-discuss] mpich2-1.3rc2.tar.tar under cygwin+WINDOWS Server 2003 R2 installation problem
Victor Gillette victor.gillette at ncsu.edu
Tue Oct 12 11:15:50 CDT 2010
However, mpiexec is running. These are the commands I entered so far:....
E:\Victor\soft\MPICH2>msiexec /i mpich2-1.2.1p1-win-x86-64.msi
E:\Victor\soft\MPICH2>mpiexec -n 2 hostname
Aborting: unable to connect to TRISO, smpd version mismatch
E:\Victor\soft\MPICH2>mpiexec -n 2 dir
Usage:
mpiexec -n <maxprocs> [options] executable [args ...]
mpiexec [options] executable [args ...] : [options] exe [args] : ...
mpiexec -configfile <configfile>
options:
standard:
-n <maxprocs>
-wdir <working directory>
-configfile <filename> -
       each line contains a complete set of mpiexec options
       including the executable and arguments
-host <hostname>
-path <search path for executable, ; separated>
extensions:
-env <variable value>
-hosts <n host1 host2 ... hostn>
-hosts <n host1 m1 host2 m2 ... hostn mn>
-machinefile <filename> - one host per line, #commented
-localonly <numprocs>
-exitcodes - print the exit codes of processes as they exit
-genvlist <list of env var names a,b,c,...> - pass current values of these
vars
-g<local arg name> - global version of local options
  genv, gwdir, ghost, gpath, gmap
-file <filename> - old mpich1 job configuration file
examples:
mpiexec -n 4 cpi
mpiexec -n 1 -host foo master : -n 8 worker
For a list of all mpiexec options, execute 'mpiexec -help2'
Thanks
Victor
On Tue, Oct 12, 2010 at 12:11 PM, Victor Gillette
<victor.gillette at ncsu.edu>wrote:
> Hi, Thanks for your answer!!
> I certainly do not know what am I doing, I just try to read manuals and
> find tutorials, quite unsuccessfully, though.
> All the installation processes I did were run under an Administrator
> account.
> I followed your instrctions and I got :
> could it be because I am running on a Windows Server 2003 R2, and not on a
> 2008??
> Suggestions are welcome!!!
> Thanks
> Victor
> On Tue, Oct 12, 2010 at 11:52 AM, <jayesh at mcs.anl.gov> wrote:
>> Hi,
>> >> ...mpich2-1.2.1p1-win-x86-64.msi... mpiexec answered something like
>> smpd was not the right version.
>>  Did you install MPICH2 from an administrator command prompt ? Windows
>> flavors Vista/7/Srv2008 need extra information in the installers for
>> installing the package as an administrator (The flavor of Visual Studio that
>> we use to compile MPICH2 does not support adding these additional info - We
>> have an open ticket on this issue,
>> https://trac.mcs.anl.gov/projects/mpich2/ticket/1070, and we plan to fix
>> it soon).
>>  We do not recommend users to use "smpd -install" to install SMPD on
>> windows (Unless you know what you are doing). The windows installer should
>> automatically install the process manager for you.
>>  Please follow the steps below and let us know if it works for you,
>> # Uninstall any versions of MPICH2 installer in your machine (Control
>> panel --> Add/Remove programs --> Uninstall)
>> # Right-click on the command prompt icon and select "Run as administrator"
>> (Note that opening a command prompt as an administrator does not give you an
>> administrator command prompt). This opens an administrator command prompt
>> # Use the msiexec utility to install MPICH2 (Type "msiexec /i
>> mpich2-1.2.1p1-win-x86-64.msi" at the administrator command prompt) from the
>> # The command above pops up the installer GUI to install MPICH2.
>> # After installing MPICH2, type "mpiexec -n 2 hostname" at the command
>> prompt to check if MPICH2 is working (The MPICH2 job launcher might prompt
>> you for user credentials to launch the executables. Provide them when
>> prompted.).
>> # Compile/Run a simple hello world program (
>> https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/f77/hellow.f)
>>  Installing MPICH2 on windows using an installer would be the easiest way
>> to getting started with MPICH2 on windows (and you get better performance
>> than MPICH2 on Cygwin).
>>  Let us know the results.
>> Regards,
>> Jayesh
>> ----- Original Message -----
>> From: "Victor Gillette" <victor.gillette at ncsu.edu>
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Tuesday, October 12, 2010 10:30:30 AM GMT -06:00 US/Canada Central
>> Subject: [mpich-discuss] mpich2-1.3rc2.tar.tar under cygwin+WINDOWS Server
>> Hi. I am interested in running MCNP parallel on a Windows Server 2003 R2
>> 64
>> bits System with Intel fortran Compiler and cygwin installed and working.
>> First I tried installing
>> but mpiexec answered something like smpd was not the right version.
>> Then I ran smpd -install
>> and when trying to run mpiexec nothing happened.
>> I read that hydra would be a more robust manager instead of smpd, so I
>> downloaded the source files of
>> because the pages with binaries were not available and I ran
>> ./configure
>> make
>> make install
>> I found some issues while make, like datatypes for Fortran were not
>> defined
>> in mpi.h of mpif.h . What I did to patch these problems is copying the
>> values for these definitions from the mpif.h and mpi.h files of the
>> previous
>> version I had installed. I have no idea if this is completely crazy or a
>> reasonable assumption, but make ended OK. There was another issue which
>> was
>> that a file setbotf.o was not found in binding/f77 but I found the
>> file setbotf.obj , so I
>> renamed the file to have .o extension and make and make install ended
>> successfully.
>> I was able to compile Hiworld.c but it doesn't run. I was not able to
>> compile Hiworld.f (datatypes ended with ")" when something else was
>> expected.
>> I created all MPICH twice the first time with all defaults, which
>> produced HYDRA, and a second time with MPD because I found no
>> explanation about how to start HYDRA in the manual.
>> With MPD I defined the file .mpd.conf in my home folder and the file
>> mpd.conf in the /etc folder
>> I started MPD with
>> mpd --ncpus=8 &
>> and if I type
>> mpdtrace
>> the code answers my system name.
>> if I type
>> mpiexec -n 4 ls
>> the output of ls is shown 4 times on the screen.
>> I can create a.exe with
>> mpicc Hi.c
>> successfully, however these are the outputs of different commands I tried:
>> $ mpiexec Hic.exe
>> missing num_proc flag: -n, -np, -hosts, or -localonly.
>> Unable to parse the mpiexec command arguments.
>> vhgillette at TRISO /cygdrive/e/Victor/MCNP/CHECK/VIC/test
>> $ mpiexec -n 2 Hic.exe
>> $ ./Hic.exe
>>  argx  2280688   argv  ô
>> Hello from processor 0 of 1
>> so, please, could anyone ive me some advise about how to run mpi
>> successfully on my system?
>> Thanks
>> Victor
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Victor Gillette, Ph.D.
> Research Associate
> Nuclear Reactor Program
> Department of Nuclear Engineering
> North Carolina State University
> P.O. Box 7909
> 2500 Stinson Dr.
> Raleigh, NC 27695-7909
> TE 919-515-3302
Research Associate
P.O. Box 7909
2500 Stinson Dr.
TE 919-515-3302
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101012/b1f79687/attachment-0001.htm>
