[mpich-discuss] mpich2-1.3rc2.tar.tar under cygwin+WINDOWS Server 2003 R2 installation problem
Jayesh Krishna jayesh at mcs.anl.gov
Tue Oct 12 11:20:46 CDT 2010
# Do you have another MPI library installed in your machine (e.g. Microsoft's MPI)?
# Is mpiexec pointing to the windows version installed using the installer (which mpiexec)?
# Is there a Cygwin version of SMPD (part of MPICH2 installed on Cygwin) running on your system ?
# What does "smpd -version" show you ?
 I would recommend that you modify the "Path" environment variable (system path) on windows such that MPICH2's bin (C:\Program Files\MPICH2\bin) directory is the first one in the path.
Jayesh
----- Original Message -----
From: "Victor Gillette" <victor.gillette at ncsu.edu>
Sent: Tuesday, October 12, 2010 11:11:30 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] mpich2-1.3rc2.tar.tar under cygwin+WINDOWS Server 2003 R2 installation problem
Hi, Thanks for your answer!!
I certainly do not know what am I doing, I just try to read manuals and find tutorials, quite unsuccessfully, though.
All the installation processes I did were run under an Administrator account.
I followed your instrctions and I got :
E:\Victor\soft\MPICH2>mpiexec -n 2 hostname
Aborting: unable to connect to TRISO, smpd version mismatch
could it be because I am running on a Windows Server 2003 R2, and not on a 2008??
Suggestions are welcome!!!
Thanks
Victor
On Tue, Oct 12, 2010 at 11:52 AM, < jayesh at mcs.anl.gov > wrote:
>> ...mpich2-1.2.1p1-win-x86-64.msi... mpiexec answered something like smpd was not the right version.
Did you install MPICH2 from an administrator command prompt ? Windows flavors Vista/7/Srv2008 need extra information in the installers for installing the package as an administrator (The flavor of Visual Studio that we use to compile MPICH2 does not support adding these additional info - We have an open ticket on this issue, https://trac.mcs.anl.gov/projects/mpich2/ticket/1070 , and we plan to fix it soon).
We do not recommend users to use "smpd -install" to install SMPD on windows (Unless you know what you are doing). The windows installer should automatically install the process manager for you.
Please follow the steps below and let us know if it works for you,
# Uninstall any versions of MPICH2 installer in your machine (Control panel --> Add/Remove programs --> Uninstall)
# Right-click on the command prompt icon and select "Run as administrator" (Note that opening a command prompt as an administrator does not give you an administrator command prompt). This opens an administrator command prompt
# Use the msiexec utility to install MPICH2 (Type "msiexec /i mpich2-1.2.1p1-win-x86-64.msi" at the administrator command prompt) from the administrator command prompt
# The command above pops up the installer GUI to install MPICH2.
# After installing MPICH2, type "mpiexec -n 2 hostname" at the command prompt to check if MPICH2 is working (The MPICH2 job launcher might prompt you for user credentials to launch the executables. Provide them when prompted.).
# Compile/Run a simple hello world program ( https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/examples/f77/hellow.f )
Installing MPICH2 on windows using an installer would be the easiest way to getting started with MPICH2 on windows (and you get better performance than MPICH2 on Cygwin).
Let us know the results.
Jayesh
From: "Victor Gillette" < victor.gillette at ncsu.edu >
Sent: Tuesday, October 12, 2010 10:30:30 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] mpich2-1.3rc2.tar.tar under cygwin+WINDOWS Server 2003 R2 installation problem
Hi. I am interested in running MCNP parallel on a Windows Server 2003 R2 64
bits System with Intel fortran Compiler and cygwin installed and working.
First I tried installing
but mpiexec answered something like smpd was not the right version.
Then I ran smpd -install
and when trying to run mpiexec nothing happened.
I read that hydra would be a more robust manager instead of smpd, so I
downloaded the source files of
because the pages with binaries were not available and I ran
./configure
make
make install
I found some issues while make, like datatypes for Fortran were not defined
in mpi.h of mpif.h . What I did to patch these problems is copying the
values for these definitions from the mpif.h and mpi.h files of the previous
version I had installed. I have no idea if this is completely crazy or a
reasonable assumption, but make ended OK. There was another issue which was
that a file setbotf.o was not found in binding/f77 but I found the
file setbotf.obj , so I
renamed the file to have .o extension and make and make install ended
successfully.
I was able to compile Hiworld.c but it doesn't run. I was not able to
compile Hiworld.f (datatypes ended with ")" when something else was expected.
I created all MPICH twice the first time with all defaults, which
produced HYDRA, and a second time with MPD because I found no
explanation about how to start HYDRA in the manual.
With MPD I defined the file .mpd.conf in my home folder and the file
mpd.conf in the /etc folder
I started MPD with
mpd --ncpus=8 &
and if I type
mpdtrace
the code answers my system name.
if I type
mpiexec -n 4 ls
the output of ls is shown 4 times on the screen.
I can create a.exe with
mpicc Hi.c
successfully, however these are the outputs of different commands I tried:
$ mpiexec Hic.exe
missing num_proc flag: -n, -np, -hosts, or -localonly.
Unable to parse the mpiexec command arguments.
vhgillette at TRISO /cygdrive/e/Victor/MCNP/CHECK/VIC/test
$ mpiexec -n 2 Hic.exe
$ ./Hic.exe
argx 2280688 argv ô
Hello from processor 0 of 1
so, please, could anyone ive me some advise about how to run mpi
successfully on my system?
Thanks
Victor
mpich-discuss mailing list
Victor Gillette, Ph.D.
Research Associate
Nuclear Reactor Program
Department of Nuclear Engineering
North Carolina State University
P.O. Box 7909
2500 Stinson Dr.
Raleigh, NC 27695-7909
TE 919-515-3302
