[mpich-discuss] cli.h file not found error
Pavan Balaji balaji at mcs.anl.gov
Sun Oct 10 21:39:11 CDT 2010
I've been trying to reproduce this problem, but it seems to work
correctly on all the platforms that I have access to.
Can you try not providing the checkpointing options to configure and see
if the error still occurs?
  -- Pavan
On 10/10/2010 05:58 PM, kishor kharbas wrote:
> Hi,
> I applied the patch procedure, no success though.
> I have attached the new out and err files, if in case patch makes
> difference to them .
> Regarding optmpixx, its another network interface(each node has dual
> nics) used for mpi communication.
> I also tried using optxx but it gives same error message.
> Thank you.
> On Sun, Oct 10, 2010 at 5:49 PM, Pavan Balaji <balaji at mcs.anl.gov
> <mailto:balaji at mcs.anl.gov>> wrote:
>     On 10/10/2010 04:06 PM, kishor kharbas wrote:
>         Attached are the error and output files with verbose option set.
>         My command line was
>         /mpiexec -verbose -f ~/hostfile -n 2 ./examples/cpi > out 2> err/
>         Hostfile contains:
>         /optmpi09/
>         /optmpi10/
>     Thanks.
>     # It looks like the hostnames of the nodes are "opt09" and "opt10",
>     and "optmpi09" and "optmpi10" are some other aliases?
>     # You did try pinging "optmpi09" from "optmpi10" and vice-versa, and
>     that worked fine, correct?
>     # Did you try pinging "opt09" from "opt10" and vice-versa? Did that
>     work correctly?
>     Assuming that the answers to the above questions are all yes, can
>     you try the attached patch?
>     % cd <mpich2-source> ; patch -p1 < ifname.patch
>     % make && make install
>       -- Pavan
>     Pavan Balaji
>     http://www.mcs.anl.gov/~balaji
> /Kishor Kharbas/
> /MS Student
> Department of Computer Science
> NC State University//
> Raleigh, NC 27606/
Pavan Balaji
