[mpich-discuss] cli.h file not found error
kishor kharbas kishor.kharbas at gmail.com
Sun Oct 10 23:07:12 CDT 2010
I installed it again without BLCR support, but still no luck.
Please let me know if you need additional information about my environment.
Thank you for your support till now.
On Sun, Oct 10, 2010 at 10:39 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> I've been trying to reproduce this problem, but it seems to work correctly
> on all the platforms that I have access to.
> Can you try not providing the checkpointing options to configure and see if
> the error still occurs?
>  -- Pavan
> On 10/10/2010 05:58 PM, kishor kharbas wrote:
>> Hi,
>> I applied the patch procedure, no success though.
>> I have attached the new out and err files, if in case patch makes
>> difference to them .
>> Regarding optmpixx, its another network interface(each node has dual
>> nics) used for mpi communication.
>> I also tried using optxx but it gives same error message.
>> Thank you.
>> On Sun, Oct 10, 2010 at 5:49 PM, Pavan Balaji <balaji at mcs.anl.gov
>> <mailto:balaji at mcs.anl.gov>> wrote:
>>    On 10/10/2010 04:06 PM, kishor kharbas wrote:
>>        Attached are the error and output files with verbose option set.
>>        My command line was
>>        /mpiexec -verbose -f ~/hostfile -n 2 ./examples/cpi > out 2> err/
>>        Hostfile contains:
>>        /optmpi09/
>>        /optmpi10/
>>    Thanks.
>>    # It looks like the hostnames of the nodes are "opt09" and "opt10",
>>    and "optmpi09" and "optmpi10" are some other aliases?
>>    # You did try pinging "optmpi09" from "optmpi10" and vice-versa, and
>>    that worked fine, correct?
>>    # Did you try pinging "opt09" from "opt10" and vice-versa? Did that
>>    work correctly?
>>    Assuming that the answers to the above questions are all yes, can
>>    you try the attached patch?
>>    % cd <mpich2-source> ; patch -p1 < ifname.patch
>>    % make && make install
>>      -- Pavan
>>    Pavan Balaji
>>    http://www.mcs.anl.gov/~balaji
>> /Kishor Kharbas/
>> /MS Student
>> Department of Computer Science
>> NC State University//
>> Raleigh, NC 27606/
> Pavan Balaji
*Kishor Kharbas*
*MS Student
NC State University**
Raleigh, NC 27606*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101011/b295d5bb/attachment.htm>
