[mpich-discuss] cli.h file not found error
kishor kharbas kishor.kharbas at gmail.com
Sun Oct 10 17:58:17 CDT 2010
I applied the patch procedure, no success though.
I have attached the new out and err files, if in case patch makes difference
to them .
Regarding optmpixx, its another network interface(each node has dual nics)
used for mpi communication.
I also tried using optxx but it gives same error message.
Thank you.
On Sun, Oct 10, 2010 at 5:49 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> On 10/10/2010 04:06 PM, kishor kharbas wrote:
>> Attached are the error and output files with verbose option set.
>> My command line was
>> /mpiexec -verbose -f ~/hostfile -n 2 ./examples/cpi > out 2> err/
>> Hostfile contains:
>> /optmpi09/
>> /optmpi10/
> Thanks.
> # It looks like the hostnames of the nodes are "opt09" and "opt10", and
> "optmpi09" and "optmpi10" are some other aliases?
> # You did try pinging "optmpi09" from "optmpi10" and vice-versa, and that
> worked fine, correct?
> # Did you try pinging "opt09" from "opt10" and vice-versa? Did that work
> correctly?
> Assuming that the answers to the above questions are all yes, can you try
> the attached patch?
> % cd <mpich2-source> ; patch -p1 < ifname.patch
> % make && make install
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
*Kishor Kharbas*
*MS Student
Department of Computer Science
NC State University**
Raleigh, NC 27606*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101010/ff93be97/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101010/ff93be97/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101010/ff93be97/attachment-0003.obj>
