[MOAB-dev] MOAB CMake error in Windows 10
Vijay S. Mahadevan vijay.m at gmail.com
Sat Jan 28 14:41:53 CST 2023
I do not see any attachments for the logs.
> Below is my error message in CMake:
> CMake Error at src/CMakeLists.txt:352 (STRING):
STRING sub-command REGEX, mode REPLACE failed to compile regex
"^C:/Users/xwang/Dropbox/c++/Divergent3D/build/src/".
Can you tell us the CMake version that you are using?
Vijay
On Sat, Jan 28, 2023, 11:32 Xilu Wang <wangxiluwxl at gmail.com> wrote:
> Hi,
> I was trying to configure MOAB in Windows 10 via CMake, however, I got
> the following error, which is caused by lines 352 and 353 of
> src\CMakeLists.txt in the MOAB folder.
> CMake Error at src/CMakeLists.txt:353 (string):
> string sub-command REGEX, mode MATCH needs at least 5 arguments total to
> command.
> Attached are my CMakeError.log and CMakeOutput.log.
> I downloaded the source code from
> https://bitbucket.org/fathomteam/moab/src/master/, which is the latest
> version of MOAB.
> Thank you,
> Xilu
