[MOAB-dev] MOAB CMake error in Windows 10
Xilu Wang wangxiluwxl at gmail.com
Sat Jan 28 15:08:33 CST 2023
Hi Vijay,
Thank you so much for your response. Please find attached the logs and my
CMake env-variables.
Best,
Xilu
On Sat, Jan 28, 2023 at 2:42 PM Vijay S. Mahadevan <vijay.m at gmail.com>
wrote:
> I do not see any attachments for the logs.
> > Below is my error message in CMake:
> > CMake Error at src/CMakeLists.txt:352 (STRING):
> STRING sub-command REGEX, mode REPLACE failed to compile regex
> "^C:/Users/xwang/Dropbox/c++/Divergent3D/build/src/".
> Can you tell us the CMake version that you are using?
> Vijay
> On Sat, Jan 28, 2023, 11:32 Xilu Wang <wangxiluwxl at gmail.com> wrote:
>> Hi,
>> I was trying to configure MOAB in Windows 10 via CMake, however, I got
>> the following error, which is caused by lines 352 and 353 of
>> src\CMakeLists.txt in the MOAB folder.
>> CMake Error at src/CMakeLists.txt:353 (string):
>> string sub-command REGEX, mode MATCH needs at least 5 arguments total to
>> command.
>> Attached are my CMakeError.log and CMakeOutput.log.
>> I downloaded the source code from
>> https://bitbucket.org/fathomteam/moab/src/master/, which is the latest
>> version of MOAB.
>> Thank you,
>> Xilu
