[AG-TECH] Capture card
Christoph Willing
c.willing at uq.edu.au
Mon Mar 1 15:35:43 CST 2010
On 02/03/2010, at 6:15 AM, <adam.horwich at stfc.ac.uk> wrote:
> We picked up one of these cards a few weeks ago and it's proving
> troublesome with the current version of AGTk with Windows XP. The
> only time we've managed to get video out of our PAL cameras via VIC
> is by using H261AS at 'large' resolution, but unfortunately that
> does not have the correct aspect ratio (and is not something you can
> set natively in the video producer service).
> Under Linux (where the drivers are admittedly very early and
> primarily aimed at OEMs) VIC fails to output anything but the DVI
> input despite allowing you to select an individual BNC port when
> configuring your video services.
> I haven't seen what I can produce by manually launching VIC yet, but
> then that's not a scenario we would ever rely on for our AG services.
Adam,
In the AG toolkit, various settings are determined for vic in the
VideoService configuration gui. The toolkit then launches vic as if it
were being run manually from the command line and adds whatever
settings were selected.
If you are able to find good settings when running vic manually with
this card, then those settings could possibly be incorporated into the
AG toolkit's configuration gui or vic launcher.
chris
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov on behalf of Adam Taylor
> Sent: Mon 01/03/2010 19:59
> To: ag-tech at lists.mcs.anl.gov
> Subject: [AG-TECH] Capture card
> Has anyone out there used this capture card with VIC?
> http://www.datapath.co.uk/visionsd4plus1.html
> Does it work?
> Thanks,
> Adam Taylor
> Computing Center
> University of Louisiana Monroe
> Scanned by iCritical.
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
