[AG-TECH] Capture card
adam.horwich at stfc.ac.uk
Mon Mar 1 14:15:14 CST 2010
We picked up one of these cards a few weeks ago and it's proving troublesome with the current version of AGTk with Windows XP. The only time we've managed to get video out of our PAL cameras via VIC is by using H261AS at 'large' resolution, but unfortunately that does not have the correct aspect ratio (and is not something you can set natively in the video producer service).
Under Linux (where the drivers are admittedly very early and primarily aimed at OEMs) VIC fails to output anything but the DVI input despite allowing you to select an individual BNC port when configuring your video services.
I haven't seen what I can produce by manually launching VIC yet, but then that's not a scenario we would ever rely on for our AG services.
Adam Horwich.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov on behalf of Adam Taylor
Sent: Mon 01/03/2010 19:59
To: ag-tech at lists.mcs.anl.gov
Subject: [AG-TECH] Capture card
Has anyone out there used this capture card with VIC?
http://www.datapath.co.uk/visionsd4plus1.html
Does it work?
Adam Taylor
Computing Center
University of Louisiana Monroe
Scanned by iCritical.
