[AG-TECH] Capture card
adam.horwich at stfc.ac.uk
Tue Mar 2 05:20:30 CST 2010
Hi Christoph,
Yes, that is a very good point and it may be essential for operation
under Linux, but I am erring on the next release of Access Grid Toolkit
to resolve my headaches now that I have found some minor success with
the card...
Yes, I have been digging through DataPath's SDK and they mention a
registry override where resolution can be hardcoded. By setting a
352x288 entry there I have managed to get VIC to correctly display
streams from our cameras. There are two drawbacks presently, which I am
waiting to hear back about, one being that this potentially limits AGTk
from only ever displaying one resolution for all feeds (inc the DVI
input) and the second being that for PAL cameras, this does not
accommodate non-square pixels so the aspect ratio is wrong.
Adam Horwich
-----Original Message-----
From: Christoph Willing [mailto:c.willing at uq.edu.au]
Sent: 01 March 2010 21:36
To: Horwich, Adam (STFC,RAL,ESC)
Cc: ataylor at ulm.edu; ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] Capture card
On 02/03/2010, at 6:15 AM, <adam.horwich at stfc.ac.uk> wrote:
> We picked up one of these cards a few weeks ago and it's proving
> troublesome with the current version of AGTk with Windows XP. The
> only time we've managed to get video out of our PAL cameras via VIC
> is by using H261AS at 'large' resolution, but unfortunately that
> does not have the correct aspect ratio (and is not something you can
> set natively in the video producer service).
> Under Linux (where the drivers are admittedly very early and
> primarily aimed at OEMs) VIC fails to output anything but the DVI
> input despite allowing you to select an individual BNC port when
> configuring your video services.
> I haven't seen what I can produce by manually launching VIC yet, but
> then that's not a scenario we would ever rely on for our AG services.
Adam,
In the AG toolkit, various settings are determined for vic in the
VideoService configuration gui. The toolkit then launches vic as if it
were being run manually from the command line and adds whatever
settings were selected.
If you are able to find good settings when running vic manually with
this card, then those settings could possibly be incorporated into the
AG toolkit's configuration gui or vic launcher.
chris
> From: ag-tech-bounces at lists.mcs.anl.gov on behalf of Adam Taylor
> Sent: Mon 01/03/2010 19:59
> To: ag-tech at lists.mcs.anl.gov
> Subject: [AG-TECH] Capture card
> Has anyone out there used this capture card with VIC?
> http://www.datapath.co.uk/visionsd4plus1.html
> Does it work?
> Thanks,
> Adam Taylor
> Computing Center
> University of Louisiana Monroe
> Scanned by iCritical.
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
