proposal for common configuration elements for ITAPS services
Tim Tautges
tautges at mcs.anl.gov
Tue Sep 21 11:51:57 CDT 2010
This won't work for MOAB; MOAB has both an imesh and an igeom implementation, and there are (many) times when you only
want imesh, and not igeom. So, we need them individually controllable.
- tim
On 09/21/2010 11:10 AM, Mark Miller wrote:
> On Mon, 2010-09-20 at 21:18 -0700, seol at scorec.rpi.edu wrote:
>> Instead of individual option for each implementation (imesh, igeom, irel, etc), how about --enable-itaps for all.
>> In case of imeshp, having both --enable-itaps and --with-mpi (or CC=mpicc) would be interpreted as imeshp enabled.
> You know, this sure would be a lot simpler than having to remember
> several different switches. So, to paraphrase your proposal, given a
> product like FOOBAR which implements SOME of the ITAPS interfaces,
> --enable-itaps means to enable all the interfaces FOOBAR implements.
> Optionally, a product could also offer --enable-<some specific ITAPS
> interface> but that would NOT be required by 'ITAPS-compliant' software.
> ITAPS-compliance means only that --enable-itaps is an available
> configuration switch.
> I kinda like this idea.
> Mark
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
