proposal for common configuration elements for ITAPS services
Mark Miller
miller86 at llnl.gov
Tue Sep 21 11:10:09 CDT 2010
On Mon, 2010-09-20 at 21:18 -0700, seol at scorec.rpi.edu wrote:
> Instead of individual option for each implementation (imesh, igeom, irel, etc), how about --enable-itaps for all.
> In case of imeshp, having both --enable-itaps and --with-mpi (or CC=mpicc) would be interpreted as imeshp enabled.
You know, this sure would be a lot simpler than having to remember
several different switches. So, to paraphrase your proposal, given a
product like FOOBAR which implements SOME of the ITAPS interfaces,
--enable-itaps means to enable all the interfaces FOOBAR implements.
Optionally, a product could also offer --enable-<some specific ITAPS
interface> but that would NOT be required by 'ITAPS-compliant' software.
ITAPS-compliance means only that --enable-itaps is an available
configuration switch.
I kinda like this idea.
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901 M/W/Th:7-12,2-7 (530)-753-8511
More information about the tstt-interface
