iRel revisions
Mark Shephard
shephard at scorec.rpi.edu
Fri Jan 29 11:54:28 CST 2010
Was suppose to be;
Note that ....
(lost and e)
Mark Shephard wrote:
> Tim,
> Not that RPI and Simmetrix are pretty much unable to make any progress
> until the iterator-based functions. We need them as soon as possible.
> Mark
> Tim Tautges wrote:
>> Carl Ollivier-Gooch wrote:
>>> Tim Tautges wrote:
>>>> Hi all,
>>>> Based on our discussions about iRel, I've made changes to the iRel
>>>> interface header; the new version is attached, along with a revised
>>>> document describing iRel. Comments are welcome. When things have
>>>> settled down from that, I'll get this in to the ITAPS repo and
>>>> implement the changes in Lasso.
>>> A couple of comments, mostly minor:
>>> There are a couple of paste-o's where the arg type in
>>> iBase_EntitySet, but the arg name is ent*.
>> Got it.
>>> There's a comment at the top of the file that suggests that some
>>> functions will take either an entity or a set in the same argument
>>> slot, with an additional arg indicating which it is. That doesn't
>>> show up anywhere in the file (which is good, because compilers would
>>> puke on that), but the comment should be removed.
>> Oops; I thought I'd expunged all MOAB-based assumptions from iRel,
>> but they persist, as does Carl's vigilance :).
>>> Otherwise --- and with the caveat that I've not tried to implement or
>>> use it --- this looks reasonable enough to me as far as it goes.
>>> Isn't it still missing some stuff about returning iterators instead
>>> of sets on request?
>> Drat, I guess my subconscious was trying to slip that one past the
>> group. Mark B, this was (on a conscious level, anyway...) unintentional.
>> Looks like there's more work to do to add iterator-based functions. I
>> may not get to this until next week, but I'll get to it.
>>> Carl
>> A couple other changes:
>> - removed setSetArrEntArr, that's covered by setEntArrSetArr with
>> appropriate switch_order argument. For those that are really on top
>> of things (Carl), I think the setSetEntArr has to stay, because of
>> non-symmetry in the Arr part.
>> - removed comment block on Geometry-Mesh Functions, which were removed
>> from iRel
>> - tim
More information about the tstt-interface
