iRel revisions
Mark Shephard
shephard at scorec.rpi.edu
Fri Jan 29 11:48:05 CST 2010
Tim,
Not that RPI and Simmetrix are pretty much unable to make any progress
until the iterator-based functions. We need them as soon as possible.
Tim Tautges wrote:
> Carl Ollivier-Gooch wrote:
>> Tim Tautges wrote:
>>> Hi all,
>>> Based on our discussions about iRel, I've made changes to the iRel
>>> interface header; the new version is attached, along with a revised
>>> document describing iRel. Comments are welcome. When things have
>>> settled down from that, I'll get this in to the ITAPS repo and
>>> implement the changes in Lasso.
>> A couple of comments, mostly minor:
>> There are a couple of paste-o's where the arg type in iBase_EntitySet,
>> but the arg name is ent*.
> Got it.
>> There's a comment at the top of the file that suggests that some
>> functions will take either an entity or a set in the same argument
>> slot, with an additional arg indicating which it is. That doesn't
>> show up anywhere in the file (which is good, because compilers would
>> puke on that), but the comment should be removed.
> Oops; I thought I'd expunged all MOAB-based assumptions from iRel, but
> they persist, as does Carl's vigilance :).
>> Otherwise --- and with the caveat that I've not tried to implement or
>> use it --- this looks reasonable enough to me as far as it goes.
>> Isn't it still missing some stuff about returning iterators instead of
>> sets on request?
> Drat, I guess my subconscious was trying to slip that one past the
> group. Mark B, this was (on a conscious level, anyway...) unintentional.
> Looks like there's more work to do to add iterator-based functions. I
> may not get to this until next week, but I'll get to it.
>> Carl
> A couple other changes:
> - removed setSetArrEntArr, that's covered by setEntArrSetArr with
> appropriate switch_order argument. For those that are really on top of
> things (Carl), I think the setSetEntArr has to stay, because of
> non-symmetry in the Arr part.
> - removed comment block on Geometry-Mesh Functions, which were removed
> from iRel
> - tim
More information about the tstt-interface
