proposal for common configuration elements for ITAPS services
Tim Tautges tautges at mcs.anl.gov
Mon Aug 30 12:15:18 CDT 2010
What about the contents of the i*-Defs.inc, do we still have the standard that these files must define IMESH_INCLUDES
and IMESH_LIBS make variables?  That will be important to apps wanting to pull the i*-Defs.inc into their bare
(non-generated) makefiles.  I think we standardized on that awhile back, so we just need to make sure to document that.
- tim
On 08/26/2010 06:45 PM, Jason Kraftcheck wrote:
> We have decided on common configuration options used to specify the
> ITAPS implementations to be used by services. I think that it would be
> nice if all ITAPS codes followed a common convention for these options.
> I propose that the group adopt the system we use. I'll describe the
> system and the reasoning behind the choices below.
> The system we have decided on uses autoconf variables that point to the
> i*-Defs.inc file provided by the implementation. The names of the
> variables are all-uppercase of the form I*_DEFS. An autoconf variable is
> created in the configure.ac with a statement like the following:
> AC_ARG_VAR( [IMESH_DEFS] , [Path to iMesh-Defs.inc] )
> The following are examples of three slightly different syntaxes that can
> be used to configure Mesquite with iGeom and iMesh support:
> Example 1:
> ./configure IMESH_DEFS=/home/jason/moab/lib/iMesh-Defs.inc \
> IGEOM_DEFS=/home/jason/cgm/lib/iGeom-Defs.inc
> Example 2:
> IGEOM_DEFS=/home/jason/cgm/lib/iGeom-Defs.inc \
> ./configure
> Example 3:
> export IMESH_DEFS=/home/jason/moab/lib/iMesh-Defs.inc
> export IGEOM_DEFS=/home/jason/cgm/lib/iGeom-Defs.inc
> ./configure
> This system differs from other common ones in two significant ways.
> Firstly, it uses an autoconf variable rather than an --enable-* or
> --with-* flag. Secondly, the value is expected to be the full path to
> the *-Defs.inc file, rather than some directory containing the file.
> The reason for the first choice (autconf variable) is that it makes
> configuring many services that are all build against the same
> implementation(s) (e.g. all services are to be used in the same app) to
> be configured more easily. A statement like
> will store a value in the shell environment that can be used by all
> subsequent configures of different services without specifying it again.
> Allowing the value to be specified as an environmental variable is also
> more likely to be compatible with build systems that are implemented
> wiht cmake. Cmake has a very different syntax for command line
> arguments, but can still access environmental variables.
> The reason for the second choice (full path to *-Defs.inc) is that it is
> the most straightforward and least error prone way to implement the
> configure script. It is also entirely sufficient: the defs file should
> contain all the information the service needs. No other path information
> should be necessary. Many implementations currently accept a value that
> corresponds to the --prefix where the implementation was installed. They
> then expect the defs file to be at the libs/*-Defs.inc relative path.
> This will break if --libdir was specified explicitly to the configure
> script as something other than the lib/ subdir of $prefix. It also
> precludes using the i*-Defs.inc files from un-installed MOAB or CGM
> builds (which is supported).
> Another useful feature of this is that it is proof against non-standard
> names for the *-Defs.inc files, for example if a file must be re-named
> to avoid conflicts with another implementation. Finally, it is the least
> error-prone for the user if they are using tab-completion in the shell
> because by the time they have the whole option specified the shell has
> verified that it is correct (to have reached the file with tab
> completion, the file must exist.)
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the tstt-interface mailing list
