proposal for common configuration elements for ITAPS services
Jason Kraftcheck kraftche at cae.wisc.edu
Fri Aug 27 09:55:42 CDT 2010
On 08/27/2010 07:51 AM, Vitus Leung wrote:
> Jason,
> I have a concern about the second difference from common systems in that
 > a single system for all libraries, ITAPS and non-ITAPS, might be
 > easier for the user.
I agree that this is a downside of this method.  However, there are
several mitigating factors:
0) autoconf vars also appear in the help
1) autoconf vars are actually more commonly used than flags when
specifying a single file or a path to an executable
2) While using --with-whatever=<somedir> has become a fairly common
convention, it is not the documented use of the --with-* flags in the
autoconf documentation.  The autoconf docs actually seem to push a
solution where the user specifies LDFLAGS='-Lwhatever/lib ...' and
CPPFLAGS='-Iwhatever/include ...'.  Probably because:
3) Using --with-whatever=<somedir> is somewhat broken.  It cannot
accommodate things that were configured --includedir=... or --libdir=...
to be something other than the default relative path from $prefix.
- jason
More information about the tstt-interface mailing list
