iterator question.
Tim Tautges
tautges at mcs.anl.gov
Thu Oct 29 10:53:19 CDT 2009
Meaning, we haven't followed up in iGeom the changes to those concepts made in iMesh.
- tim
Tim Tautges wrote:
> I think in all cases, the iMesh interface should take precedent when
> describing concepts common to that and iGeom.
> - tim
> Mark Shephard wrote:
>> Sounds like the iGeom iterator needs to be changed.
>> Carl Ollivier-Gooch wrote:
>>>>> The Simmetrix people have been looking at the ITAPS iMesh, iMeshP,
>>>>> iRel
>>>>> and iGeom interfaces.
>>>>> One of the questions they have sent us has to do with iterators and
>>>>> is:
>>>>> "Are iMesh_getNextEntIter and iGeom_getNextEntIter supposed to have
>>>>> the
>>>>> same behavior as their documentation describes two different
>>>>> behaviors -
>>>>> iMesh_getNextEntIter indicates whether the current call returned data
>>>>> (which is fairly standard behavior for an
>>>>> iterator),iGeom_getNextEntIter
>>>>> indicates whether the next call will return data (which is kind of odd
>>>>> behavior for an iterator)."
>>>>> I would think they should have the same behavior and the iMesh
>>>>> behavior
>>>>> is the right one. Comments please.
>>>> I think (if I correctly recall the that group discussion about this)
>>>> that
>>>> the iMesh one is the correct one. Returning information about next
>>>> call, as
>>>> the iGeom one does, is not usable in mesh modification scenarios
>>>> (consider
>>>> iterator at second to last entity when last entity is deleted.)
>>> Jason has identified precisely the reason that the iMesh iterator
>>> behavior was changed.
>>> Carl
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
