iterator question.
Tim Tautges
tautges at mcs.anl.gov
Thu Oct 29 10:51:09 CDT 2009
I think in all cases, the iMesh interface should take precedent when describing concepts common to that and iGeom.
- tim
Mark Shephard wrote:
> Sounds like the iGeom iterator needs to be changed.
> Carl Ollivier-Gooch wrote:
>>>> The Simmetrix people have been looking at the ITAPS iMesh, iMeshP, iRel
>>>> and iGeom interfaces.
>>>> One of the questions they have sent us has to do with iterators and is:
>>>> "Are iMesh_getNextEntIter and iGeom_getNextEntIter supposed to have the
>>>> same behavior as their documentation describes two different
>>>> behaviors -
>>>> iMesh_getNextEntIter indicates whether the current call returned data
>>>> (which is fairly standard behavior for an
>>>> iterator),iGeom_getNextEntIter
>>>> indicates whether the next call will return data (which is kind of odd
>>>> behavior for an iterator)."
>>>> I would think they should have the same behavior and the iMesh behavior
>>>> is the right one. Comments please.
>>> I think (if I correctly recall the that group discussion about this)
>>> that
>>> the iMesh one is the correct one. Returning information about next
>>> call, as
>>> the iGeom one does, is not usable in mesh modification scenarios
>>> (consider
>>> iterator at second to last entity when last entity is deleted.)
>> Jason has identified precisely the reason that the iMesh iterator
>> behavior was changed.
>> Carl
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
