Entity sets - containment and parent-child
Tim Tautges tautges at mcs.anl.gov
Thu Nov 12 11:36:59 CST 2009
I figured you'd ask that next.  The two that come to mind most readily:
a) I use entity sets to represent geometric topology groupings in the mesh, and parent/child relations between those to
represent the topological relationships between the original geometric entities.  So, I have "model face" sets, whose
contents are the mesh owned by that model face, and children corresponding to the bounding model edges.  Instead of
directly including the mesh faces in a model face set, say I want to preserve a grouping of those faces, e.g. the
original rectangles of faces composing an "E" or "L" shaped structured mesh.  This would most naturally be stored as
rectangle sets of faces contained in the model face set.  Similar examples can be made for swept meshes in 3d.
b) Parts in a parallel mesh: parent-child relations can be used to represent the relationship between parts and their
boundaries.  If you construct a partition using e.g. material sets or model volume sets, then a part set will have both
child sets (the boundaries of the part) and contained sets (the model volumes composing the part).
- tim
Mark Beall wrote:
> I'd be interested in knowing the various use cases for using entity set
> containment vs. a parent-child relationship. It seems to me that they
> are just about identical, so I'm curious when one would use one vs. the
> other.
> mark
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the tstt-interface mailing list
