Entity sets - containment and parent-child
Mark Beall mbeall at simmetrix.com
Thu Nov 12 11:18:25 CST 2009
On Nov 12, 2009, at 12:06 PM, Jason Kraftcheck wrote:
> Mark Beall wrote:
>> So the only substantial difference between the containment and
>> parent-child relationship is that I can ask for the parents of an
>> entity
>> set in a parent-child relationship whereas I can't in a containment
>> relationship (although the ability to do that would be easy enough to
>> add).
> How easy it is to add would depend on the implementation.
>> In the containment relationship, the contained sets do play a part
>> in the entity set operations, but it would be trivial to ignore
>> them in
>> the results.
> I'm not sure what you mean.  The contained sets take part in things
> like
> boolean operations.  The effect such operations have on contained
> sets would
> be reflected in the output of getNumEntSets, getEntSets and
> isEntSetContained.
Yes, but the entity sets only take part in the boolean operations with
other entity sets, so there are really two boolean operations going on
at once (one with the entities in the set and one with the entity sets
in the set), so if I don't look at the entity sets in the result, it
doesn't matter if they are there or not.
I'd be interested in knowing the various use cases for using entity
set containment vs. a parent-child relationship. It seems to me that
they are just about identical, so I'm curious when one would use one
vs. the other.
mark
More information about the tstt-interface mailing list
