Proposal for telling an implementation what adjacency info an app/service needs
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Wed Nov 11 10:48:21 CST 2009
Tim Tautges wrote:
> There are cases where there will be variations in capabilities between
> implementations, without there being enough commonality to justify
> binding in the API. The easiest example is load and save options. In
> that case, an application must either ifdef directly to the
> implementation's syntax, or use a string option and test the return
> value of the function. Either way the application will need to handle
> the case where the capability isn't available. With options, the code
> is cleaner and there's a middle ground of possibly ignoring the option.
Fair enough, although there should probably be feedback about which of
multiple options have been ignored.
> And, remember, I don't advocate doing this widely, just in a few cases
> where specialized behavior has far-reaching consequences. I have
> several examples that have been encountered already, one of them
> resulting in bad press for ITAPS (the sparse vs. dense tags thing).
You gotta admit, though, that citing sparse vs. dense tags as an example
of the need for a string arg doesn't strengthen your case, since that
one is a binary choice, -and- we're all likely to be happy to take
advantage of dense storage internally.
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
