[Swift-user] Channel Timeout on Beagle?
Matthew Shaxted
Matthew.Shaxted at som.com
Wed May 27 14:03:38 CDT 2015
Hi All: I was able to get the runs working successfully by changing the maxtime flag in the sites file.
Thanks
Sent: Wednesday, May 27, 2015 9:50 AM
To: Swift User
Subject: Channel Timeout on Beagle?
Hi Swift Users:
I am running some studies on Beagle using Swift, and experiencing a strange error. The Swift scripts run great on cloud and on the Beagle login node, but seems to be timing out for some reason.
Does anyone have insight into the cause of this? Thanks for any help.
Below is the error I am getting:
Host: cluster
Directory: epsweep-run004/jobs/a/RunEP-ai2mic9m exception @ swift-int-staging.k, line: 181
Caused by: exception @ swift-int-staging.k, line: 177
Caused by: Block task failed: Connection to worker lost
org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=150526-142313.128,
50526-142514.107, channel=TCPChannel [type: server, contact: 0526-0802460-000014-000456
at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
at java.util.TimerThread.mainLoop(Timer.java:566)
at java.util.TimerThread.run(Timer.java:516)
Below is my sites.xml file:
<pool handle="cluster">
<execution provider="coaster" jobmanager="local:pbs" />
<profile namespace="globus" key="project">CI-SES000178</profile>
<profile namespace="globus" key="jobsPerNode">24</profile>
<profile namespace="globus" key="lowOverAllocation">100</profile>
<profile namespace="globus" key="highOverAllocation">100</profile>
<profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
<profile namespace="globus" key="maxtime">10800</profile>
<profile namespace="globus" key="maxWalltime">01:25:00</profile>
<profile namespace="globus" key="userHomeOverride">/lustre/beagle2/mattshax/epsweep/swifthome</profile>
<profile namespace="globus" key="slots">20</profile>
<profile namespace="globus" key="maxnodes">600</profile>
<profile namespace="globus" key="nodeGranularity">1</profile>
<profile namespace="karajan" key="jobThrottle">180</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<!-- <profile namespace="karajan" key="workerLoggingLevel">trace</profile> -->
<workdirectory>/dev/shm/mattshax/swiftapp</workdirectory>
</pool>
MATTHEW SHAXTED
SKIDMORE, OWINGS & MERRILL LLP
224 SOUTH MICHIGAN AVENUE
CHICAGO, IL 60604
T (312) 360-4368
MATTHEW.SHAXTED at SOM.COM<mailto:MATTHEW.SHAXTED at SOM.COM>
[cid:image001.png at 01D09885.EDB6D900]<http://www.som.com/>
The information contained in this communication may be confidential, is intended only for the use of the recipient(s) named above, and may be legally privileged. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited and may be unlawful. If you have received this communication in error, please return it to the sender immediately and delete the original message and any copy of it from your computer system. If you have any questions concerning this message, please contact the sender.
[cid:image002.gif at 01D09885.EDB6D900]
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150527/4b8ed3ed/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150527/4b8ed3ed/attachment.png>
Type: image/gif
Desc: image002.gif
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150527/4b8ed3ed/attachment.gif>
More information about the Swift-user
