[Swift-user] hung submission
Mihael Hategan hategan at mcs.anl.gov
Sun May 3 15:06:21 CDT 2015
It seems that it is more likely that the error message gets truncated
rather than the path itself. After all, stdout_path_list does contain
what seems to be the correct path.
There should be a
script: /imports/home1/tcrnma3/Scratch/UrbanModel/run005/scripts/SGE7948718974736431209.submit
(or similar) that should be available while a swift run is in progress.
I think one way to troubleshoot things would be to copy that script and
submit it manually.
Mihael
On Sun, 2015-05-03 at 19:20 +0000, Altaweel, Mark wrote:
> Yes so I do import swift in the shell script that gets distributed. However, same conclusion it seems. I don’t understand why it truncates the path, unless it is there but only writes a certain number of the characters.
> This is added to the script:
> export PATH=$PATH:~/Scratch/swift-0.96-sge-mod/bin
> module load java/1.7.0_45
> So java is included. If I remove it same thing happens though.
> Mark
> On May 3, 2015, at 8:07 PM, Mihael Hategan <hategan at mcs.anl.gov<mailto:hategan at mcs.anl.gov>> wrote:
> On Sun, 2015-05-03 at 18:43 +0000, Altaweel, Mark wrote:
> error reason    1:          05/03/2015 19:38:15 [147447:22761]: error: can't open output file "/imports/home1/tcrnma3/Scratch/Ur
> ... aaand my PE suggestion had little to do with the problem.
> Is /imports mounted on compute nodes?
> Mihael
> Swift-user mailing list
> Swift-user at ci.uchicago.edu<mailto:Swift-user at ci.uchicago.edu>
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
