[Swift-user] hung submission
Altaweel, Mark m.altaweel at ucl.ac.uk
Sun May 3 14:20:34 CDT 2015
Yes so I do import swift in the shell script that gets distributed. However, same conclusion it seems. I don’t understand why it truncates the path, unless it is there but only writes a certain number of the characters.
This is added to the script:
export PATH=$PATH:~/Scratch/swift-0.96-sge-mod/bin
module load java/1.7.0_45
So java is included. If I remove it same thing happens though.
On May 3, 2015, at 8:07 PM, Mihael Hategan <hategan at mcs.anl.gov<mailto:hategan at mcs.anl.gov>> wrote:
On Sun, 2015-05-03 at 18:43 +0000, Altaweel, Mark wrote:
error reason    1:          05/03/2015 19:38:15 [147447:22761]: error: can't open output file "/imports/home1/tcrnma3/Scratch/Ur
... aaand my PE suggestion had little to do with the problem.
Is /imports mounted on compute nodes?
Mihael
Swift-user mailing list
Swift-user at ci.uchicago.edu<mailto:Swift-user at ci.uchicago.edu>
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150503/8a4455a8/attachment.html>
More information about the Swift-user mailing list
